 Footbrake rod J2
MIKEB
Posted - 25/09/2016 :  15:25:54  Show Profile
Does anyone have a spare footbrake rod (pedal to cross shaft) please? No joy so far from the usual suppliers. Thanks Mike
Andy Rogers
Posted - 25/09/2016 :  17:51:54  Show Profile
Oh dear Mike. I'm looking for one too but was relying on Mike Dowley to supply.
Here's hoping there's someone out there who knows of a source for both of us.
Andy Rogers
TCTom
Posted - 26/09/2016 :  17:15:10  Show Profile
Mike and Andy, Digby Elliott makes these. Check with him to see if he has any on hand.
Tom Wilson
Zionsville, IN USA
Posted - 26/09/2016 :  20:29:58  Show Profile
I am about to make a small batch for my D and two local J owners.
They will be from solid square stock as the first one from tube proved not strong enough.
I could add one or two more, though it might take a month or two before they are finished.
Onno "D" Könemann
Foz
Posted - 26/09/2016 :  22:19:45  Show Profile
Onno,
early D ... short chassis.... parts are different to cope with the shallower and shorter chassis side rails.... so check what you need .....Late D and J dims are the same.
FOZ
Orstin
Posted - 26/09/2016 :  22:44:38  Show Profile
I had to resolve this problem a while back. The correct tubing is known as 4130N tubing and can be sourced from UK companies who supply materials for home built aircraft, e.g. Sky-craft ltd. This link takes you to the page:
http://www.sky-craft.co.uk/acatalog/Skycraft_Home_Builder_Permit_Aircraft_Steel_Stock_4130_Tube.html
£15.70 per foot for 9/16" x 0.12 wall, and it should come with a certificate of conformance.
Mention in dispatches goes to Lew Palmer and John Reid who came up with the original spec.
So many dynamos
Edited by - Orstin on 26/09/2016 22:45:53
MIKEB
Posted - 26/09/2016 :  23:01:10  Show Profile
Many thanks for those leads chaps. I may decide to make my own, but since you are currently manufacturing a batch Onno could you I've me some idea of the expected price?
Mike Bangs
Gary K
Posted - 27/09/2016 :  01:07:30  Show Profile
FOZ
Do you happen to know how much shorter the shaft is on the Early D. The first one I made for my early D did not fit correct. Now I know why, it was a copy from my J2.
Thanks
Gary
Posted - 27/09/2016 :  06:46:00  Show Profile
Mike
Will try to this week
Foz
Thanks, 0495 is long enough ;)
Onno "D" Könemann
Foz
Posted - 27/09/2016 :  12:16:02  Show Profile
Gary,
Total length is 15 1/2"
length between pin centres is 14 5/*'
length of tube between ends is 12 1/4"
Lever arm on brake cross shaft is approx 1/4" shorter than on the later cars, so does not project above top of chassis rail.
hope this helps
FOZ
Foz
Posted - 27/09/2016 :  12:18:31  Show Profile
oops ... should be 14 5/8"
ONNO proper IMPERIAL measurements !
FOZ
Gary K
Posted - 27/09/2016 :  13:27:59  Show Profile
Thank You
