sullivan
423 Posts |
Posted - 29/09/2016 : 23:56:21
Looking for a water Outlet to place onto water jacket covers for P-type
Brian W Sullivan |
Edited by - sullivan on 30/09/2016 15:59:00 |
Foz
770 Posts |
Posted - 04/10/2016 : 17:28:28
BRIAN, I have one of these brass fittings. Email me if still in need of it. FOZ |
1575 Posts |
Posted - 04/10/2016 : 23:07:30
Brian, Sorry to be pedantic, but
![](http://www.triple-mregister.org/forums/uploads/Bruce Sutherland/2016104225624_P Type engine LHS X ex orig manualX.jpg) The the aluminium manifold off the side of the cylinder head is the water/coolant outlet, thus the lower brass elbow on the cylinder block water jacket plate is the inlet. (NOTE: When a water pump is fitted, the inlet plate may be re-positioned to the rear block aperture). - cooled 'cold' water IN at the bottom, hot OUT at the top.
sullivan
423 Posts |
Posted - 04/10/2016 : 23:21:20
Hi Bruce, When I started the search for this part I indeed noted this request as "Looking for a water inlet". After no response and looking through the "library" that came with the car I was still unsure of the name. When checking our suppliers I noted them calling the water jacket plate hole a water outlet. This then is why I changed the title of my search to that name. I understand cooled water enters through this location and exits the upper manifold.
Best,
Brian W Sullivan |
sullivan
423 Posts |
Posted - 05/10/2016 : 16:24:54
Pleased to report original Inlet has become available.
Best,
Brian W Sullivan |
1575 Posts |
Posted - 06/10/2016 : 00:00:29
Hi Brian, I understand the difficulty when incorrect nomenclature is used to describe parts. Another one is the inverted 'U' hoops and rubbers fitted over the P Type rear axle which is frequently called a 'rebound stop' rather than a 'bump stop' ....... suspension bump travel is upwards, rebound is down. ![](images/icon_smile_approve.gif)
sullivan
423 Posts |
Posted - 06/10/2016 : 03:40:15
Bruce, On top of all that I speak American...
Doing my best to follow what's being said. :)
Best,
Brian W Sullivan |
1575 Posts |
Posted - 06/10/2016 : 10:00:49
Brian, "On top of all that I speak American..."
From the northwest USA, nearly close enough to speak 'Canadian', almost one us then!!..................but the language is called 'ENGLISH' . Cold winters up there, so make sure you use a good quality anti-freeze - 50/50 mix to get plenty of corrosion protection as well. See http://www.triple-mregister.org/uploads/retro/Engine_cooling.pdf We'll get there in the end. Cheers. Bruce
Foz
770 Posts |
Posted - 06/10/2016 : 14:30:43
Brian, water manifold.... inlet to block.....ready to send to you. The other one is F-type.... FOZ
![](http://www.triple-mregister.org/forums/uploads/Foz/2016106143022_DSCF1234.JPG) |
1240 Posts |
Posted - 06/10/2016 : 20:53:02
Bruce. (PB0564)
Bruce
In winter I prefer a mix of 9 parts Ballvenie antifreeze to 1 part water. 50/50 ruins the 'antifreeze'.
Peter |
sullivan
423 Posts |
Posted - 06/10/2016 : 22:30:25
Thank you Gents,
Look's fantastic Foz.
At this time and for some time yet PA 1024 is protected O2 antifreeze. I dream of the day I drive from my rural home to my rural work shop...
Kindly,
Brian W Sullivan |
1575 Posts |
Posted - 07/10/2016 : 11:01:27
quote: [i]Originally posted by Peter Scott Bruce In winter I prefer a mix of 9 parts Ballvenie antifreeze to 1 part water. 50/50 ruins the 'antifreeze'. Peter
So, you like running on a weak mixture then!!!!!! don't overheat your valves. ![](images/icon_smile_wink.gif)
