 Search Tip
NeilS
Posted - 31/01/2017 :  08:36:46  Show Profile
I'm not sure how much this will be general knowledge within the forum so I will share.
I have found that the boards own embedded search is perhaps not the best throwing up a limited number of results.
I have found far better results by using Google to search the register site. You can use google to search specific sites by adding the following after your search string
site:www.triple-mregister.org.
so for example
M Type vertical drive site:www.triple-mregister.org
Neil
Posted - 31/01/2017 :  08:55:26  Show Profile
Thanks Neil,
Yes, this was mentioned by somebody a while back when the forum search function was playing up.
PA/PB 0743
Posted - 31/01/2017 :  10:13:06  Show Profile
You don't need to bother with the www. It's sufficient to type site:triple-mregister.org
Posted - 31/01/2017 :  12:53:09  Show Profile
I have tried a couple of searches e.g. "M-type springs" and the website search turned up 26 hits even finding posts about distributor springs, all relevant to Triple-M cars. A Google searched turned up hundreds of hits including many completely irrelevant (to me) finds such as: "Apartments to rent in Macon Ga", "Linear and non-linear springs tutorial" to name just two.
Just saying.
NeilS
Posted - 31/01/2017 :  13:45:21  Show Profile
That is odd Nick, I tried the same search with the Site:triple-mregister.org qualifier and got nothing but results from the register site, I wonder if there is a difference in US google.com Vs Google.co.uk would be odd if there was.
It was just my experience earlier that the site search threw up very few (about 3) on a search that brought up about 20 relevant results on the qualified Google search
Neil
Posted - 31/01/2017 :  19:13:52  Show Profile
An advantage of the Google search is that it searches both the archived and non-archived areas so it saves having to do two separate searches.
Peter
