Andrew Fock
374 Posts |
Posted - 02/04/2018 : 00:41:27
Hi James,
It was thin plywood. Not sure on the quality...all pretty rotten now. These cars are not from my car but from a friend (who lives about 800 miles away!). I note on Pat's car that the seats and the door cards etc are a different colour. What is the correct "green" for an NA? I'd be keen for a set of the patterns Dave if you are happy to send them?
(my car was re-trimmed in the 70's rather badly!)
Thanks
Andrew
NA 0279 PA 1294 |
671 Posts |
Posted - 02/04/2018 : 08:07:06
Was there much sewing through the entire card? I thought most only went through the covering/wadding. This was then attached from the rear with staples and glue. I am quite happy to be proved wrong though! |
g waiting
729 Posts |
Posted - 02/04/2018 : 09:31:25
Hi James, I have some original TC trim panels, they are made of 3 ply, about 4 mm, probably 5/32", thick. The quality is good, about the same as birch ply but the really noticeable thing is just how thin the rexine covering is. As you know , the hidem is sewn straight through it all. Garry |
thecollingburnboys
574 Posts |
Posted - 02/04/2018 : 10:45:02
Was there much sewing through the entire card? I thought most only went through the covering/wadding. This was then attached from the rear with staples and glue. I am quite happy to be proved wrong though! [/quote]
Yes, a trimmer uses glue and staples to attach the covering material: vinyl or leather but sometime through P-Type production, as J2s didn't have it, they started sewing around the semi-circle pocket cutout to stop the vinyl lifting around this area. I use very good spreadable contact adhesive like Thixofix so will only sew through the door cards if the customer asks for it and 1 of my 2 heavy industrial machines is playing ball. I had one of my machines serviced by a retired 72 year old sewing machine engineer who had been trained since leaving school and he told me off when I told him I did it, said he had never seen it before and that to his knowledge no sewing machine had been designed to sew through hard wood. Morris/MG really were revolutionary in the way they solved problems. Hidem banding (hidem gimp or double welt piping) is widely used in other old cars and marine trimming, old and modern but they staple it on afterwards through the middle, they never sew it on through wood.
Regards James Collingburn |
Edited by - thecollingburnboys on 02/04/2018 11:02:11 |
thecollingburnboys
574 Posts |
Posted - 02/04/2018 : 10:50:05
[quote]Originally posted by g waiting
Hi Garry, yes there is no doubt about it, hidem was sewn onto the trim panel through the middle of the hidem and the stitch formed on the rear of the wood. Luckily I don't do many T-Types now as it isn't good for the sewing machine. I've downsized our operation, I'm just one man in a small unit... and ofcourse, I prefer making interiors for MMM :-). PS original Rexine was thin, it was like paper, easy to wrap around awkward shapes but looks cheap and creases easily. I have 2 machines that will sew through 3-4mil ply without hidem but as soon as I introduce the hidem it struggles. So now I stick it on with strong double-sided sticky tape and then staple through the middle and ofcourse it gets panel pins banged through the middle of it to fit the panels to the car so the stitching is handy but not essential. Thankfully MMMs were produced before the wide use of hidem so it isn't a problem with those. Yet another reason why I prefer MMM interiors to T-Types :-)
Edited by - thecollingburnboys on 02/04/2018 11:11:30 |
671 Posts |
Posted - 03/04/2018 : 10:16:51
Thamks James, that makes more sense to me now, I'm just not used to modern cars like T types! I have one more question for you but I'll send that in a separate email
Kevin |
