PLC switch clamp
Topic Locked
Tony Dolton
Posted - 17/09/2017 : 08:37:22
Does anyone know a supplier of the spring clamp that holds the switch into the instrument panel.I'm missing one for the J2.Rather not use a jubilee clip or similar device. Thanks Tony.
Posted - 17/09/2017 : 10:51:19
If you struggle I can probably find you one but the postage may be more than the part
Tony Dolton
Posted - 19/09/2017 : 08:52:30
Thanks Kevin, but there must surely be someone in the UK who can help!
Will wait patiently.
Posted - 20/09/2017 : 00:19:08
Maybe this
https://www.completeautomobilist.com/products/836c-plc-clip
Tony Dolton
Posted - 20/09/2017 : 06:21:31
Thanks Kevin,a simple solution!
I've also been offered one locally,so problem solved.many thanks Tony
Topic Locked
© 2003-2024 MGCC
