sullivan
423 Posts |
Posted - 04/10/2017 : 23:04:20
Looking for a correct P-Type 12 volt Lucas Altette HF934 For PA1024 Thank you in advance.
Kindly,
Brian W Sullivan |
1578 Posts |
Posted - 04/10/2017 : 23:52:14
Brian, I got mine from: L. Issac, 20 The Glebe, Bishopston, Nr Swansea SA3 3JP. www.taffthehorns.com
sullivan
423 Posts |
Posted - 05/10/2017 : 00:04:22
Bruce,
Good call, I thought that as well...
contacted Taff to no avail... Took several tries and once successful he explained that he had none.
Brian W Sullivan |
ANDY KING
309 Posts |
Posted - 05/10/2017 : 17:44:12
Hi Brian, I have attached photos for your information, could this one be what you are looking for? It is 12V, tested and working. With a little work, the chroming may come up ok? Angie King 01949 860519
![](http://www.triple-mregister.org/forums/uploads/ANDY KING/201710517425_IMG_1616.JPG)
![](http://www.triple-mregister.org/forums/uploads/ANDY KING/2017105174239_IMG_1619.JPG) |
sullivan
423 Posts |
Posted - 05/10/2017 : 18:56:31
Dear Andy,
Thank you for pictures of the Altette horn you have. The horn shown according to Taff is the 1949/1950 HF 1234 or 1235. I am searching for a original HF 934. Currently the car came with a ceramic coated body Altette Vincent 1000 Cast Iron body horn. The proper one is pressed steel according to Taff.
Kindly,
Brian W Sullivan |
Edited by - sullivan on 06/10/2017 00:52:06 |
ANDY KING
309 Posts |
Posted - 05/10/2017 : 19:59:45
Hi Brian Many thanks for your reply. We do have many others in stock and will have a look in our boxes tomorrow. Angie King |
sullivan
423 Posts |
Posted - 06/10/2017 : 00:48:06
Now after looking carefully over Taff site I see my Altette is a Vincent 1000 form.
Someone in past fitted as replacement for the original lost somewhere along the way... so I have a really nice Vincent Altette.....
![](http://www.triple-mregister.org/forums/uploads/sullivan/201710604535_IMG_1605.JPG)
![](http://www.triple-mregister.org/forums/uploads/sullivan/20171060463_IMG_1606.JPG)
![](http://www.triple-mregister.org/forums/uploads/sullivan/201710604634_IMG_1601.JPG)
Brian W Sullivan |
ANDY KING
309 Posts |
Posted - 06/10/2017 : 07:23:17
Hi Brian, As promised, initial search has located the attached.Not sure on voltage. Sounds on 12V - perhaps Nick Feakes can inform us if damage could be caused by putting 12V through a 6V horn? The previous horn we pictured before has now found a good home in Somerset! Angie
![](http://www.triple-mregister.org/forums/uploads/ANDY KING/201710671546_IMG_1631.JPG)
![](http://www.triple-mregister.org/forums/uploads/ANDY KING/20171067166_IMG_1632.JPG)
![](http://www.triple-mregister.org/forums/uploads/ANDY KING/201710671639_IMG_1633.JPG) |
3393 Posts |
Posted - 06/10/2017 : 12:41:46
Provided you are not prone to extended sounding of the horn, I think it would be OK. Nick |
sullivan
423 Posts |
Posted - 06/10/2017 : 17:44:01
Thank you all ! The correct part has now been sourced. A wonder this forum is indeed.
Very Best,
Brian W Sullivan |
