 differential
spatek
Posted - 13/10/2017 :  20:43:20  Show Profile
After my mechanical problems on the Kernow tour I find I have the same problem as Terry Hartley a broken diff I have a spare one but its not the right ratio for an Ftype does anyone know of a source of new crownwheel and pinions? the breakdown did not spoil the excellent as I got to navigate in John Emetts lovely J1 TW
Blithe Spirit
Posted - 14/10/2017 :  09:30:36  Show Profile
Vintage and Classic Shock Absorbers had the high ratio cw&ps in stock when I last checked. They were made by Guest Gears so are good quality, but your casing and/or axle tube may need fettling to clear. I certainly had to grind a bit out of my steel casing when I fitted one to my J3.
Glad you still enjoyed the event; what a wonderful collection of Abingdon's finest.
David
spatek
Posted - 14/10/2017 :  17:25:05  Show Profile
I will give them a call thank you, TW.
Posted - 14/10/2017 :  18:34:42  Show Profile
Sorry to hear that, Terry. Good luck with finding a replacement.
PA-PB0743
Posted - 15/10/2017 :  11:41:46  Show Profile
Roger Furneaux (Mad Metrics) also advertises new 4.875 ratio c.w.& p. sets (8/39) suitable for F, D, J & Ps although whether these are 6 bolt or 8 bolt fittings, I don't know. Roger supplies a lot of c.w.& p sets to T Register Racers and they don't mess about.
O.Thomas
Posted - 15/10/2017 :  12:24:23  Show Profile
He supplies Ford Escort ones as well then -))
spatek
Posted - 19/10/2017 :  19:02:21  Show Profile
I have ordered a crown wheel & pinion from Graham Brown from vintage shockabsorbers he has various ratios drilled for 6 or 8 bolt fixings so I should soon be mobile and ready for Scotland next year thanks for your help Terry W.
