 Starter Spiral Spacer
pauly45
Posted - 19/12/2017 :  19:27:54  Show Profile
Following my post regarding starter motor gear engagement, I thought I would see if there are any of the long spiral spacers around to see if I can improve gear engagement.
The part I think I'm after is the red arrowed part shown below.
I am assuming that this spiral will fit the gear on my starter, if not, I guess I would then be after a matching gear also.
Many thanks
Paul
george
Posted - 19/12/2017 :  20:23:50  Show Profile
Paul I think that you need to change the whole rotating assembly as they are quite different . I think that I may be able to photograph the bits [if I can find them] tomorrow . I don't think that there is anything wrong with the one you have, the thick and thin spacers can be swapped . Geoff
chris Wallis
Posted - 21/12/2017 :  08:55:29  Show Profile
Hi Paul
the assembly of the spacers and the scroll are the wrong way round, if you can give me a call on 01332 703630 it will be easier to explain what you need to do [not a big job]. Chris Wallis.
C L Wallis
george
Posted - 21/12/2017 :  12:44:13  Show Profile
Sorry Paul but no photo, the starter with the short Bendix is on the car. The splines on your starter with a light spring finish about 20mm short of the motor end plate so the long Bendix will not reach the end.Geoff
george
Posted - 21/12/2017 :  13:37:14  Show Profile
