SV4670
304 Posts |
Posted - 15/01/2018 : 11:04:15
I am looking for 12/12 type down draught inlet manifold and carburettor for my M type. I have been told a Austin seven inlet manifold can be adapted to fit, can anyone comment on this?
Edited by - SV4670 on 15/01/2018 11:05:26 |
O.Thomas
755 Posts |
Posted - 15/01/2018 : 12:08:26
Andy king does the inlet manifold |
powerplus
599 Posts |
Posted - 15/01/2018 : 12:20:19
Derek,
I have a spare 1 1/8” Downdraught SU carb, together with float bowl,which is of later period than M type, but it should do the job. Located in Cheshire to view. Photo available. £40 + postage.
Powerplus. |
g waiting
729 Posts |
Posted - 15/01/2018 : 15:02:29
Hi Derek, Austin seven fits with slightest modification, I have done 2 of them. If you decide to go up to 1 1/4" su I can probably supply enough bits, but would need to check. Garry |
3109 Posts |
Posted - 17/01/2018 : 09:41:47
This is one of Garry's.
![](http://www.triple-mregister.org/forums/uploads/sam christie/201811794029_BF 5508 Carburettor and Manifold JPEG.jpg)
3679 Posts |
Posted - 17/01/2018 : 10:14:20
Very nice, Sam. Is that 2M1168 perchance?
3109 Posts |
Posted - 17/01/2018 : 11:21:08
It is indeed 2M1168. The high carburettor needs a fuel pump which in turn has allowed the petrol tank to be more safely mounted at the back.
SV4670
304 Posts |
Posted - 17/01/2018 : 13:25:52
Brilliant thanks for this. I am trying to find out which model of Austin Seven had this manifold fitted, maybe an Ulster or type 65. Will continue my quest and report back |
673 Posts |
Posted - 17/01/2018 : 21:15:35
I've no actual personal knowledge on this but my Austin 7 book by Rinsey Mills says these were fitted to the 65, 75, Nippy & Speedy models (not the Ulster as that used a steel manifold) |
Posted - 18/01/2018 : 11:07:26
Derek. Have you tried Austin Repro in Dorset ? Willie MacKenzie makes many parts for Austins.
Orstin
637 Posts |
Posted - 18/01/2018 : 13:45:13
John Barlow supplies this - amongst other styles of 'special' inlet manifolds...
http://www.austin7spares.co.uk/
hth...
So many dynamos |
SV4670
304 Posts |
Posted - 18/01/2018 : 16:50:00
Thanks for that, will get in touch with him |
