 Rear number plate and Horn bracket
Gary K
Posted - 01/02/2018 :  13:29:18  Show Profile
I'm in need of a rear number plate with only one ear for the tail light. The usual suppliers do not carry this anymore.
The bracket that clamps to the steering column that holds the horn button on a D.
I have the horn button part.
Arrangement can be made to pickup at MG day at Stoneleigh
Thanks
Gary
Posted - 01/02/2018 :  14:33:45  Show Profile
Gary, I have a buck on which I shaped a backing plate for my PA. You needn't use it to make two ears, only one.
PA1169, PB0560
rustcollector
Posted - 01/02/2018 :  16:32:19  Show Profile
Hey Lew,
Need to make one myself, what did you use for the buck. Any chance of a picture
Posted - 01/02/2018 :  17:38:26  Show Profile
I don't have a picture, but it is simply a piece of MDF or hardwood which is in the shape of the plate holder. The plate material was tapped around the edges of the buck and then heavy wire was laid in to the edge and the plate gently tapped around the wire to form a finished and slightly raised edge.
PA1169, PB0560
rodamos
Posted - 01/02/2018 :  22:07:48  Show Profile
There is a steering column stalk currently on uk ebay (item number 162873324021) with what appears to be the original style horn button.
Rod
Gary K
Posted - 01/02/2018 :  23:44:01  Show Profile
Thanks for the Ebay Find.
Talk to you on Tuesday Lew.
Gary
Adrian Moore
Posted - 03/02/2018 :  17:50:22  Show Profile
I have the horn stalk if you’re still looking
Adrian Moore
Gary K
Posted - 03/02/2018 :  20:26:57  Show Profile
Adrian
Email sent
Edited by - Gary K on 03/02/2018 20:30:04
Adrian Moore
Posted - 04/02/2018 :  16:37:50  Show Profile
No email received Gary
Adrian Moore
paul55
Luxembourg
Posted - 05/02/2018 :  20:13:14  Show Profile
https://www.ebay.co.uk/itm/Vintage-MG-vscc-horn-dip-switch/162882747025?hash=item25ec917a91:g:950AAOSwPOhaUqPJ
just found this on ebay, looks like the bit you need Gary
Paul.
Posted - 05/02/2018 :  21:59:22  Show Profile
Similar but not the same methinks... My wires appear from under the stalk rather than through a hole and there is a raise square section that lets them out. A square channel then covers them as they run away along the steering column, held between the stalk and the column at this and and by a circlip (I think) at the lower end...
P
Gary K
Posted - 17/02/2018 :  03:06:14  Show Profile
Still looking for a used one ear rear number plate. I would prefer a original one. If not located will make one.
Thanks for any leads
Gary
