 P type carbs
douglas
Posted - 11/08/2018 :  21:58:54  Show Profile
wanted for my PB a set of carbs please
Posted - 12/08/2018 :  11:03:54  Show Profile
Have a look at: https://www.ebay.co.uk/itm/232859160685 if you have not already done so.
They look a little expensive to me but I am not in need of a set. No connection to me I just spotted them on one of my regular E-bay trawls. They have been around on E-Bay for some time.
Brian Watson
Posted - 12/08/2018 :  12:30:22  Show Profile
Paul,
You should inspect the photos of those carbs carefully as the bowls and tops are not a matching pair and one of them has been drilled out at the base to accept a bolt to replace stripped threads inside the bowl. I think the price is eye-watering and then you'll have to fork out even more money to restore them.
Have you tried Andy King? His stock is always changing and you may get lucky.
Brian
Posted - 12/08/2018 :  12:35:39  Show Profile
Douglass I have e mailed you direct re a pair of P type carbs. Please check your junk folder because e mails via the forum often end up there !
TH
