Blueberry
80 Posts |
Posted - 13/09/2018 : 17:24:10
I am looking for a pair of the shaped washers that go on the gearbox input shaft one each side of the input shaft bearing. These washers are referred to and illustrated in G. Howell’s book “A Practical Guide to the Restoration of the J Type. If anyone has a pair they wish to sell, that would be wonderful. I would also be prepared to make a pair of washers if someone could supply the correct dimensions of the washers including the thickness of the metal.
I do hope you are able to help.
CJHILL |
1529 Posts |
Posted - 13/09/2018 : 18:43:39
It sounds as though you mean the hardened washers with a chamfered bore either side of the needle roller bearings. If so, there is only one to the rear of the needle roller which is recessed into the back of the input shaft. It is peculiar in that there isn't one in front of it.
Or, have I misunderstood which washers you are referring to? |
Edited by - kimber on 13/09/2018 18:45:00 |
Blueberry
80 Posts |
Posted - 13/09/2018 : 19:17:01
I have the five spacers to which you refer. It is the two washers either side of the input shaft bearing, a the one on the gearbox side of bearing is concave and could be an oil thrower, the other one is flat. From the picture in the book they are about 2” Dia. and 0.050” thick.
CJHILL |
1529 Posts |
Posted - 13/09/2018 : 20:01:57
Aha! Those washers! I haven't got any to hand I'm afraid but doubtless someone will have spares or be able to give you measurements. |
3101 Posts |
Posted - 14/09/2018 : 09:40:37
![](http://www.triple-mregister.org/forums/uploads/sam christie/201891493656_Gearbox Cogs and clutch JPEG.jpg)
Are you thinking about part numbers 28 and 29?
![](http://www.triple-mregister.org/forums/uploads/sam christie/201891410215_Washers JPEG.jpg)
Edited by - sam christie on 14/09/2018 10:21:51 |
Blueberry
80 Posts |
Posted - 14/09/2018 : 17:15:58
Yes those are the two washers I need, so much easier when you have a numbered drawing.
Many thanks Sam for clarifying the exact parts required, just need to find s pair now.
CJHILL |
3101 Posts |
Posted - 20/09/2018 : 14:45:40
Detail from Morris Minor four speed -
![](http://www.triple-mregister.org/forums/uploads/sam christie/201892014326_Scan 1.jpeg)
In the absence of a better answer I hope these pictures help.
![](http://www.triple-mregister.org/forums/uploads/sam christie/2018920143927_W3 JPEG.jpg)
![](http://www.triple-mregister.org/forums/uploads/sam christie/201892014403_W5 JPEG .jpg)
![](http://www.triple-mregister.org/forums/uploads/sam christie/2018920144048_W2 JPEG.jpg)
![](http://www.triple-mregister.org/forums/uploads/sam christie/2018920144156_W1 JPEG.jpg)
And the least accurate measurement which is roughly 2.5 to 3mm.
![](http://www.triple-mregister.org/forums/uploads/sam christie/2018920144230_W4 JPEG.jpg)
Blueberry
80 Posts |
Posted - 20/09/2018 : 15:42:11
Hi Sam, thank you so much for the dimensions, I can work with these in the absence of the actual washers.
CJHILL |
george
862 Posts |
Posted - 23/09/2018 : 09:45:00
In the exploded diagram posted by Sam the layshaft is shown with plain bearings not Hyatt . Does anybody know which gearbox types used plain bearing layshafts ? Geoff |
3101 Posts |
Posted - 23/09/2018 : 11:36:54
The plain bearings were fitted to the earliest versions (Sanction 50) of this gearbox. The plain bearings last really well.
![](http://www.triple-mregister.org/forums/uploads/sam christie/201892311364_Wolseley Special JPEG.jpg)
george
862 Posts |
Posted - 23/09/2018 : 15:58:12
Thanks Sam ,I take it then that no MMM car was originally fitted with plain bearings as sanction 50 is an early hornet saloon ? The reason that I ask is that I now have a gearbox with L type bellhousing, MMM rear housing [vertical speedo drive]both with the larger diameter register holes for the plain bearings [which it has] .The casing of the box has no sanction number stamping at all.Geoff |
6131 Posts |
Posted - 23/09/2018 : 18:39:30
Sam,
Do you have the legends that go with your two drawings? I ask because in the one for the Morris Minor four speed there are seemingly two dished oil thrower washers - part number variously P76, P134 and P53 - and in the first (and last) drawing there seems to be only one, namely part number 29. (I'm assuming that in the latter drawing part number 28 is the locking nut and part number 27 is the lock wire.)
3101 Posts |
Posted - 24/09/2018 : 00:39:37
Wolseley -
![](http://www.triple-mregister.org/forums/uploads/sam christie/201892403251_Oil Throwers 1 JPEG.jpg)
I do not believe I have the four speed Minor legend.
Edited by - sam christie on 24/09/2018 00:42:12 |
6131 Posts |
Posted - 24/09/2018 : 07:53:38
Interesting, Sam, as number 28 is clearly different to 29 yet in the four speed. Inor box the oil throwers are the same, i.e. they have the same part number. Is that a drawing of the three speed box?
3101 Posts |
Posted - 25/09/2018 : 09:52:22
The drawings above show four speed Wolseley Hornet gearboxes.
It is likely the exploded diagrams created with the first version of the Wolseley four speed gearbox were only updated as Wolseley felt absolutely necessary. Clearly the Hyatt bearings needed to be added.
The Hornet three speed (below) and the OHC Minor parts lists show a driven plate with a cone shaped centre but very few people have ever seen one like this and as far as I can see the illustrations were never updated.
![](http://www.triple-mregister.org/forums/uploads/sam christie/201892593429_Hornet three speed drive plate JPEG.jpg)
I believe the Minor four speed diagram shows the oil throwers correctly because it was a fresh and updated drawing. Here the oil throwers have the same number.
![](http://www.triple-mregister.org/forums/uploads/sam christie/201892595040_Minor four speed Sanction 74 JPEG.jpg)
Edited by - sam christie on 25/09/2018 10:14:14 |
