bloodysalmon
Spain
1482 Posts |
Posted - 13/01/2019 : 10:59:18
Following an apparent oil shortage causing a rear main bearing seizure on my D-type engine, I need to replace the front 'sump to pump' oil pipe. I'll need a new or excellent conditioned replacement please.
Chris Blood D-type Salonette D0407, TC1472 TC2686 TC4245 |
ja.mcnab
204 Posts |
Posted - 13/01/2019 : 13:19:24
How do I attach a photo - might be what you are looking for ? |
6190 Posts |
Posted - 13/01/2019 : 14:02:44
Chris,
Maybe worth trying Barry Foster?
1474 Posts |
Posted - 13/01/2019 : 14:23:15
Sometimes it's through sucking in air at the sump/pipe joint. I've bolted a block there (using the original bolt holes) and fitted a Wade connection. |
1977 Posts |
Posted - 13/01/2019 : 14:37:11
Click on Reply to Topic immediately at the bottom of the thread, not the "Quick Reply" box at the very bottom, then you will see:
"Click here to attach a photo to your post" at the bottom of the box that then appears.
Edited by - coracle on 13/01/2019 14:46:49 |
bloodysalmon
Spain
1482 Posts |
Posted - 13/01/2019 : 16:47:46
Cheers Allan, I await your photos ... Good advice on the rebuild, check the gaskets are sealed well. I've tried Barry but with no response; I thought he'd stopped doing these bits now anyway? I suspect I crushed the pipe getting the engine out so may not have been the problem in the 1st place; but I know the volume of oil in the pump casing and the rocker box was minimal ... yet oil pressure was 70psi. What else could allow the white-metal to fuse itself to the rear flange ... wrong setup or no oil! Not sure I'm going to be certain to what was the cause ... I just need to make sure the rebuild is right - perhaps I'll start another string on this subject in the technical.
6190 Posts |
Posted - 13/01/2019 : 19:15:10
Me too, but I thought it was worth suggesting.
1474 Posts |
Posted - 14/01/2019 : 10:19:46
I was confused by a previous post. I thought the sleeve had fused to the taper but it's the bearing that melted and attached to the sleeve. If you had 70pounds pressure it won't be the suction side. Rear bearing too tight perhaps? |
David R
289 Posts |
Posted - 14/01/2019 : 11:50:03
I got one from S&V not too long ago for the J2 and it was very nicely made and fitted perfectly.
David
J 3355 |
ja.mcnab
204 Posts |
Posted - 14/01/2019 : 13:25:07
Photo over 5MB so can't upload - could send to your email |
6190 Posts |
Posted - 14/01/2019 : 15:12:16
If you're using Windows, right click on the image file in Explorer and select 'resize'.
1977 Posts |
Posted - 14/01/2019 : 16:34:49
If you're using Windows, right click on the image file in Explorer and select 'resize'. Simon J J3437
And on some versions you have to use "Edit" which takes you to where you can resize |
bloodysalmon
Spain
1482 Posts |
Posted - 27/01/2019 : 14:09:18
I am still after a sump to pump pipe if any one has a good one spare? Can pick up at Stoneleigh. Looks as though S&V don't have any as no response to requests!
3421 Posts |
Posted - 27/01/2019 : 14:53:35
Alan Now that digital image sizes have increased along with improved cameras, I have increased the maximum allowed image file size to 10Mb. Of course, the larger the file size the longer the upload will take. The upload program reduces the file size before displaying the picture so it is still worth setting the camera resolution (file size) so that the upload doesn't take all day. Nick
poulsendk
Denmark
270 Posts |
Posted - 29/01/2019 : 08:48:39
Hi Chris. Is this what you are looking for ? It is from my M type sump to pump
I can bring it to Stoneleigh Jorgen Poulsen
MGM 1930 MGM 1931 |
ja.mcnab
204 Posts |
Posted - 29/01/2019 : 09:28:37
Jorgen's one looks better than mine anyway ! Allan |
