bernard.scott
194 Posts |
Posted - 14/01/2019 : 12:10:49
Engine rebuild fund running out fast!
Looking for used, good condition, 57mm forged pistons with floating pins for Phoenix rods.
Bernie Scott |
Edited by - bernard.scott on 14/01/2019 17:07:36 |
2574 Posts |
bernard.scott
194 Posts |
Posted - 14/01/2019 : 20:11:53
Thanks Dave, your reply much appreciated.
I have a new block so would hope to bore for 57mm pistons.
I wonder if Chris (Westbury) ever found the six he was after?
Bernie Scott |
2054 Posts |
Posted - 14/01/2019 : 21:03:54
Hello, Bernard.
Just noticed your comments. The answer is no, I didn’t ever find any more of these pistons, unfortunately !
I hope you are more successful.
Chris |
2574 Posts |
Posted - 14/01/2019 : 21:56:03
Hi Bernie, it is of course entirely up to you what you do with your new block but I chose a different route. As the new blocks are made for use as PA or PB and as I would not be destroying history, I opted for 60mm bore. Just a thought.
Good luck either way,
bernard.scott
194 Posts |
Posted - 14/01/2019 : 22:39:13
Thanks Dave. 60mm. Now that is food for thought!
Bernie |
6190 Posts |
Posted - 14/01/2019 : 22:42:44
A J2 block may not be quite so accommodating! But if not, 60 thou oversize, or 58.5mm, is probably feasible.
2574 Posts |
Posted - 14/01/2019 : 23:36:12
Silly of me Simon! For some reason I'd got the idea into my head that we were talking of a P. Perhaps Claire's right; dementia here we come.
Befuddled of Sussex |
2165 Posts |
Posted - 15/01/2019 : 00:11:50
A Chromidium should accommodate 60mm Simon.
You would need to check your block casting spec Bernard although these were typically fitted to Morris Minors, some Ms and, C types I believe.
bernard.scott
194 Posts |
Posted - 15/01/2019 : 08:23:21
Thanks Richard.
My block is a new casting from S and V for J2, so I think that I’ll go for 57mm pistons at present.
That said, the discussion is very interesting concerning what can be done with different blocks. I did have a Morris block in the engine that suffered a failed crank but it was not Chromidium and was not a sound basis for a rebuild.
Bernie |
robin
177 Posts |
Posted - 15/01/2019 : 11:45:14
Hello Bernie.Are you going racing?If not,I would just use standard JP or similar.Weigh them,gap the rings,should not give you any problems.
robin |
bernard.scott
194 Posts |
Posted - 15/01/2019 : 12:29:36
Dear Robin,
The more I’ve read up on the topic and from the helpful replies here, I think my planned use of the car would be well served by standard pistons as you and others have suggested. New ones are affordable in my budget, I’m pleased to discover.
I’m after a reliable road-going engine and I’ve come to understand better the amazing range of specifications to which people build their engines; especially the high revving racing cars!
Many thanks to everyone for such helpful guidance.
Bernie Scott |
2165 Posts |
Posted - 15/01/2019 : 19:29:31
My understanding is that the Colin Tieche block patterns now used were made to accommodate a thicker cylinder wall to accommodate 60mm.
The problem however with new block castings is discovery of occasional porosity in bores when machined to size, so it can be a risk if you get to 60mm and find an imperfection as it then just adds expense to the job
Edited by - Richard Hardy on 15/01/2019 19:31:43 |
bernard.scott
194 Posts |
Posted - 16/01/2019 : 20:32:21
Blimey something else to worry about!
Good point Richard. What a horror it would be to uncover a casting flaw when bored to limits. I suppose liners would have to go in.
I’m going to bore to recommended clearance for whatever 57mm pistons I finally fit. That’ll give me a few tries if boring reveals flaws.
Bernie
2165 Posts |
Posted - 17/01/2019 : 07:23:48
It certainly doesn't happen every time Bernard but something certainly to be wary of. Close inspection recommended
bernard.scott
194 Posts |
Posted - 18/01/2019 : 12:08:00
Closing statement.
Have ordered standard pistons. Thanks to all for sharing your knowledge, experience and advice. I’ll weigh them and set gaps as suggested by Robin.
Bernie Scott |
