A bit optimistic,but has anybody got a pair of J2 carb float chambers they are prepared to part with? The carbs appear to be SU OM type and Burlen catalogue them as H Type 20deg Right Hand AUC 3495,but at a price! Mine have been altered in the past by drilling though the bottom and clamping the lids by a long threaded rod with a nut at each end and appropriate washers. Probably the threads in the boss at the bottom stripped. This has worked OK during my 15 years of ownership but now leaks and I cannot seal the bottom satisfactorily with fibre washers and sealant.
Hi David I have the 3495s but normally they are the smaller 1355s. I have both pairs in stock - good used.If you can let me know by return e-mail I should be able to help you with these. Andy 01949 860519
