 HV2 carburettor
lyons-lewis
South Africa
Posted - 24/11/2020 :  06:43:51  Show Profile
I am looking for a carburettor body or complete unit for my M type.
Throat diam 1 1/8" (28.575mm) and horizontal bolt fixing 2 3/16" (55.5mm) centres. I have a 1" carb. so many of the parts are interchangeable. I can build up a unit from all the bits, if I have the correct size body
Posted - 24/11/2020 :  10:03:59  Show Profile
Bronze or ali?
Do these have vertical spindles or horizontal?
lyons-lewis
South Africa
Posted - 24/11/2020 :  11:18:31  Show Profile
Horizontal spindle and Ali is fine - bronze comes with gold-plated prices!!!
Posted - 25/11/2020 :  11:42:33  Show Profile
If you get the right kind of body you'll need a 1+1/4" carb for the bits. From what I've seen only the smaller type as fitted to Sprites and post war Minors accepted 1" carb parts.
Posted - 25/11/2020 :  13:11:31  Show Profile
Kevin's question reminds me of this carburettor -
Could a vertical spindle carburettor body be converted to horizontal spindle?
Another challenge is that the mounting holes on the flange are about half a hole wider . The difference is exaggerated in this picture.
Is a conversion possible?
tonym
Posted - 25/11/2020 :  14:20:10  Show Profile
Many years ago I purchased half of a 1 1/8" bronze carb. pair from Barry Walker
He told me that they were off an L-Type.
It was a perfect fit to the M-Type manifold.
It was when Barry was still in Kent - so I suppose he has parted with the other half by now !
Edited by - tonym on 25/11/2020 14:21:48
Posted - 25/11/2020 :  20:05:41  Show Profile
So the bronze float chamber works OK on an M-type?
Edited by - sam christie on 25/11/2020 20:35:20
Orstin
Posted - 26/11/2020 :  08:57:30  Show Profile
As I understand it, the bronze bodies with the vertical spindle are a Riley version...
So many dynamos
tonym
Posted - 26/11/2020 :  14:14:10  Show Profile
What is your point Sam ??
Obviously it works on an M-Type.
And yes, I realise that the top you show is opposite to mine.
lyons-lewis
South Africa
Posted - 26/11/2020 :  15:11:28  Show Profile
At the end of the day, this is not solving my problem!! Does anybody have a carburettor or a body for me??? Hope springs eternal
Edited by - lyons-lewis on 26/11/2020 15:11:53
Reinout
Posted - 27/11/2020 :  05:18:38  Show Profile
There is a SU on the tradersform, that might be what you’re looking for. See Barrie Walker’s post named Some MMM Oddments.
Complete original 1&1/8th bronze MG 'M/D' genuine carburettor...
Reinout Vogt
Emma
1931 M-Type 2M/2735
lyons-lewis
South Africa
Posted - 27/11/2020 :  05:30:35  Show Profile
Thanks very much. Price is a bit too rich for me at our poor rate of exchange!!!
