 quick release steering wheel
JCB
Posted - 03/12/2020 :  17:07:34  Show Profile
Dear Forum:
My question was getting lost in the last posting.
So will start from the top.
Is there a quick release steering wheel option for MMM cars.?
If a new replacement; will need to be period sympathetic.
All the best.
John Bakewell
Ktype
Posted - 03/12/2020 :  17:36:49  Show Profile
My advice would be only to do this with great care. There are race weld - on bosses that can be (expertly) welded to the top of the column and have a relatively discreet flange. To disconnect the wheel the flange is squeezed closer to the boss. Example below:
https://gsmperformance.co.uk/product-category/in-car-equipment/steering-wheels-accessories/quick-release-kits/
Anything like this should be new from an impeccable source or crack tested. So when you confidentially turn the steering wheel the front ones faithfully follow
paul55
Luxembourg
Posted - 03/12/2020 :  19:24:00  Show Profile
John, I got my lever assembly from https://www.svwspares.co.uk/ and had to modify it as Chris has already said. Give them a try.
Paul
tjackson
Posted - 03/12/2020 :  23:13:59  Show Profile
Several of the P-types imported to Australia as rolling chassis and fitted with doorless bodies when new now have removal steering wheels to accommodate the aging legs of current owners.
The boss on the steering column is not welded and the original steering wheel center can be reinstated making the process reversible. The removable center is a proprietary product but I can’t find now who supplies them. John - if you contact me I can give you the details of who fitted it to the car.
tjackson
Posted - 03/12/2020 :  23:30:06  Show Profile
John - a search for "WILWOOD QUICK RELEASE STEERING WHEEL HUB" should find the part, it looks like they are available to suit different diameter steering columns
JCB
Posted - 04/12/2020 :  08:25:40  Show Profile
Paul,Paul and Forum:
Thank-you for your details.
Will carefully consider your emails.
All the best.
John Bakewell
