Keith Durston
711 Posts |
Posted - 09/02/2021 : 16:39:35
quote: Originally posted by Ian Grace
I think it is important that - close up if need be - one can tell an original from a reproduction chassis plate. For the benefit of future researches. I wouldn't want to see pure counterfeits out there.
I agree Ian. Although I have some regret that I leant my original Coupe plate to the Triple M Register years ago as the sample for the reproduction plates to be made. I still have their letter of apology when after using it as the basis of the reproductions they then went and lost it!![](images/icon_smile_angry.gif) Keith |
3107 Posts |
Posted - 09/02/2021 : 18:00:47
The S&V ad says "Guarantee Plates ... etched and filled as original."
The etching technology is relatively straightforward.
Ian Grace
661 Posts |
Posted - 09/02/2021 : 18:32:59
One other small thing to bear in mind. When a car returned to the works to have a replacement engine fitted (as was not infrequent, as recorded in the chassis files), then a new chassis plate was fitted - with both the chassis and engine number stamped. Frank Ashley's early Oxford-built 1929 M (2/M333) is a case in point. It returned to the (Abingdon) in 1931 for a replacement engine. Since the company name/address was now incorrect, a new plate was fitted (The M.G. Car Co. Ltd, Abingdon-on-Thames) - this time with both the chassis number and new engine number stamped onto the plate.
So, if you are planning to fit a reproduction plate, probably a good idea to check the history of your car for any works engine replacements - and when they were done. |
PreWarMG
428 Posts |
Posted - 09/02/2021 : 23:32:00
Thanks - I should clarify that M1524 was a chassis only export to Australia, and was used in competition in the 1930's. It was only "discovered" and restored in the 1990's and it is unknown when the chassis plate was lost. It may never have been fitted to the locally made body ?. I had some issues when trying to re-register the car in 2019, and would like to fit a reproduction plate.
I will contact S&V.
Safety Fast Tony
We are here for a good time, not a long time !. |
Ian Grace
661 Posts |
Posted - 10/02/2021 : 17:47:38
Tony, that is an interesting thought. The chassis plates on Minors was screwed to the firewall, and the firewall was pre-fitted to export chassis during production (so it was not strictly part of the body).
On the other hand, M plates were screwed to the woodwork at the front end of the body, so the chassis plate could not have been pre-fitted by M.G. before export, so it would have been up to the coachbuilder to find somewhere to fit it - or not. |
1474 Posts |
Posted - 10/02/2021 : 18:49:32
Does Frank Ashley know? I think he was under the impression that his car had the very early 20bhp engine but would it not have been replaced with current 1931 version? Of course that's a long time ago and it could have been changed again. |
Ian Grace
661 Posts |
Posted - 10/02/2021 : 19:34:49
It was Frank who sent me the info and its backed up by the chassis file entry.
The original engine fitted was 92A in June 1929. 226A was fitted 17th July 1929, then 219B was fitted 29th September 1931 and finally 236B was fitted 4th November 1931. Sounds like quite a lemon!
If I had time, I'd like to search for these replacement engine numbers in the chassis files of other M Types to see if they were originally fitted in other cars and returned under their gurantees - as opposed to being spare units. I suspect the former.
I have a de Havillland Queen Bee (pilotless drone version of the Tiger Moth). These were used for gunnery practice and when they were shot down (over the sea), the wrecks were recovered and the Gipsy engines (of high value) were recovered, reconditioned and installed in the next Be on the production line. The current engine in my Bee had been fitted to ten earlier machines! |
Ian Grace
661 Posts |
Posted - 10/02/2021 : 19:37:27
Also, note that the Morris Service Sheet for engine overhauls states, "All re-conditioned power units are modernised as far as is practicable."
So I think it safe to assume that these engines that were replaced in 1931 would have had the 12/12 cam fitted. |
PreWarMG
428 Posts |
Posted - 11/02/2021 : 04:05:55
Ian, Do you have any photos of export chassis - Minor or MG ?. Re-reading my "Oxford to Abingdon" today revealed a large number of "chassis only" builds in 1930 & 31. The Carbodies list of bodies produced for MG Midgets in the same period is also interesting to read. There were a lot more M-Type Special Bodies than I imagined.
Tony
Rudy
9 Posts |
Posted - 11/02/2021 : 19:46:51
Thanks for the additional plates - keep them coming! The M.G. Car Company Ltd. was registered on 21st July 1930, so it will be most interesting to find chassis plates for cars that were recorded as having their chassis laid down around that date.
Hey Ian, It was 5 days earlier ![](images/icon_smile.gif)
![](https://www.triple-mregister.org/forums//uploads/Rudy/2021211194553_IMG_3152D.jpg)
Ian Grace
661 Posts |
Posted - 12/02/2021 : 16:51:16
Thanks Rudy! I guess it might have taken a few days to become official. These days, with all our instantaneous worldwide communications technology, it would probably take weeks!
Tony, I'll attach a link here to an article on export chassis that I wrote for the Autumn 2020 Vintage Minor Register magazine. It includes a photo which you sent me of your 2/M1524 alongside Bill Fuller's 2/M1523, taken at their reunion in 2016. I believe these were the only two known M Type export chassis - at least to Australia.
http://www.vintageminor.co.uk/M%20175%20-%20Export%20Chassis.pdf |
Ian Grace
661 Posts |
481 Posts |
Posted - 15/02/2021 : 16:23:55
Interesting discussions! Could David, AFM 781, please email me! Many thanks. No contact in the 'Profile'!!
Mike Dalby |
