TCTom
281 Posts |
Posted - 01/12/2021 : 23:51:23
Will I find any markings on axles for MMMs that would identify them to a specific model or chassis number? I've just acquired the remnants of an L1, without chassis or body. I know the original chassis number, have not yet looked at the engine number or the gearbox number. Thanks in advance for pointers. Once I get it all sorted out I will send updated info to the L Registrar.
Tom Wilson Zionsville, IN USA |
F0355
South Africa
298 Posts |
Posted - 02/12/2021 : 07:17:03
Hi Tom,
On the top of the pumpkin you should find some stamped numbers.
Twin breather P types had a 165 product code, single crank case breather N Types would have a 134 product code as shown in the attached. The number 367 suggests this then comes from an early N Type. For the rest of the variants I'm sure, others will chime in.
Apologies for the size of the attached image, all attempts to reduce it's size failed.
![](https://www.triple-mregister.org/forums//uploads/F0355/20211227748_N Type_1.jpg)
Peter Johannesburg, RSA
1729 Posts |
Posted - 02/12/2021 : 08:12:53
Tom up there by the freezing lake...
If you are going to need a new chassis, The Trumans in Idle near Bradfor made my replacement F one and I would recommend them.
The axles possibly had different part numbers depending on model, not sure, but I think. someone will know.
P
TCTom
281 Posts |
Posted - 02/12/2021 : 11:29:14
Thanks Peter. I’m familiar with Russ Truman’s chassis work. Excellent!
njnh
405 Posts |
Posted - 02/12/2021 : 11:37:03
When visiting Russ (who straightened my J2 chassis) I drove through Idle and was delighted to see the "Idle Men's Club"
Nigel H |
F0355
South Africa
298 Posts |
Posted - 02/12/2021 : 11:38:03
Hi Tom,
Just to clarify, on my N Type rear axle with number 367, this does not relate to the chassis number in any way but only to the rear axle number.
tonym
654 Posts |
Posted - 02/12/2021 : 14:47:33
Nigel
Just to be accurate it is the Idle Working Mans Club
Make of that what you wish ! |
6152 Posts |
Posted - 02/12/2021 : 14:59:42
Yous is both wrong - 'tis the Idle Working Men's Club & Institute ![](images/icon_smile_big.gif)
![](https://www.triple-mregister.org/forums//uploads/Simon Johnston/202112214596_90118DD2X8A64X4391X8F5DX4C6707558C86.jpeg)
tonym
654 Posts |
Posted - 03/12/2021 : 14:14:49
Pedant |
1729 Posts |
Posted - 03/12/2021 : 15:19:23
And they knock off early so don't be late! |
6152 Posts |
Posted - 03/12/2021 : 15:28:39
quote: Originally posted by tonym
Pedant
![](images/icon_smile_big.gif) ![](images/icon_smile_big.gif) ![](images/icon_smile_big.gif)
1050 Posts |
Posted - 03/12/2021 : 18:13:35
In the old printed registers the first few pages had the number markings of axles etc. Helps you identifying what car the spares might be for as without a knuckle you’ll never have the car
Onno "J,D,M" Könemann |
