 Perfecta badge
ht1962
Posted - 12/11/2023 :  20:51:43  Show Profile
Hello,
Is there a right/wrong place for the perfecta badge on the windscreen. My car (L2023) has a single little hole on the front but before i take the screen apart to change the bottom rail. I would like to know what is the opinion about the “right” position.
Kind regards
Halbe
Drolshagen
Posted - 13/11/2023 :  11:42:42  Show Profile
Hi Halbe,
is the right place for the badge,
picture from L2036
cheers
Carl
J2 4362
L2 2036
i.thomson
Posted - 13/11/2023 :  12:03:27  Show Profile
But does it go on the outside or the inside. That is the question.
Ian Thomson
Drolshagen
Posted - 13/11/2023 :  12:12:43  Show Profile
so far I can see inside
cheers
Carl
J2 4362
L2 2036
ht1962
Posted - 13/11/2023 :  13:47:16  Show Profile
Thanks Ian and again Carl ! I will change it to inside !!
Atb. Halbe
Edited by - ht1962 on 13/11/2023 13:51:04
F0355
South Africa
Posted - 14/11/2023 :  09:25:50  Show Profile
Some other opinions here: https://www.triple-mregister.org/forums/topic.asp?ARCHIVE=true&TOPIC_ID=3463
Peter
Johannesburg, RSA
Posted - 14/11/2023 :  09:42:07  Show Profile
Back home, Peter?
Best regards,
Posted - 14/11/2023 :  09:51:54  Show Profile
This cropped from a photo taken in 1935. No sign of a badge on the outside of the screen.
ht1962
Posted - 14/11/2023 :  11:14:32  Show Profile
So its seems not to be so straight forward with the badge either on the inside or outside.
Reading through all the replies and the thread from Peters reply it seems that most were on the inside but to be absolutely sure about my windscreen I will take the botom rail out and see how it fits the best, not looking at the little hole, then put the badge on.
Thank you all for your help !!
Atb Halbe
John Brinkmann
Posted - 14/11/2023 :  17:17:18  Show Profile
Halbe:
Look at it this way: if you were the manufacturer, where would you put it? You have to be rather close to read that little badge, and you'd want it to be clean and legible to those who might care, even with the screen folded flat.
John.
J3752
Roger Cadogan
Posted - 15/11/2023 :  11:36:18  Show Profile
A J2 and a PA plus a very old unrestored windscreen from a J2 and my vote goes for "Inside"
Roger
johnmereness
Posted - 15/11/2023 :  18:28:11  Show Profile
Unrestored JY 2022 - screw holes in bracket align better for "inside" matched to outside was more finish worn than inside.
JMM
Harry
Canada
Posted - 15/11/2023 :  18:36:32  Show Profile
Vote for inside, two unrestored p windscreens had this.
timothy edwards
Posted - 20/11/2023 :  16:16:50  Show Profile
The Perfecta badge on my F2 early windscreen is on the outside and has been for the 60 years I have had the car.
