rodm
156 Posts |
Posted - 01/10/2014 : 12:45:40
Hi Gerhard I well rembember our meeting at Silverstone, where you brought your beautiful white ND. What has happened to the time!
Re the "special" engine, I believe that the Abbey bodied cars were fitted with the NE manifold and 11/4 carbs instead of the usual 1 1/8 carbs.
I don't know about the camshaft, but I suppose that could also have been NE timing.
Unfortunately the original engine was missing from my car when I got it and NA 0780 has a 3 carb manifold (K?) I may be able to contact the owner of NA0696 and we may be able to learn more Best wishes Rod |
mgrog
6 Posts |
Posted - 01/10/2014 : 13:16:48
I have been in contact with the owner of NA 0696 and have current pictures (Rod, I will contact you off line about this). That car has a two carb set up. Rod, your observation is interesting. Tom (Metcalf) and I had figured that the three carb set up on mine (NA 0780) was put on later, but perhaps the car originally came with the K set up. Tom has the car now, and I will contact him to find the engine number and other details. Another detail that I am trying to decifer on mine is the dashboard. Mine has been completely altered with modern (50's) gauges. The rev counter may be original with a newer face, to be determined. So, the layout that Abbey used will be a challenge, and also the gauges, as Tom thinks that my high number (0780) indicates that this was made when the works had converted to NB's. I thank all of you for your help so far, especially Rod. I was fairly sure that I was going to pass this car to someone else to bring it back, but with the information, history and offers of help that I have received, I am enthusuastic about saving and preserving this very special car. Tom Metcalf has done two cars for me (PA, TC) and both are stunning and most important, accurate. I will work with him on 0696. Looking forward to more comments and help. Much appreciated and needed.
Roger |
mgrog
6 Posts |
Posted - 01/10/2014 : 13:19:53
Ooops! Sorry guys, I said I would be working on 0696. I meant 0780, which is my car. I will leave 0696 to someone else!
Roger |
3376 Posts |
Posted - 09/10/2014 : 13:54:02
Roger Please see the reply from James Collingburn now on the Trader's forum Nick
