2310 Posts |
Posted - 19/09/2018 : 10:15:57
I don't think there is much of a problem with the photo you have; the blurry background is due to the use of a wide aperture on a lens with a relatively long focal length. The intended subject matter is quite sharp (blow up the 4 and look at the edges.)
A higher resolution is unlikely to make the blurry number plate any sharper.
Worth a try though- good luck. |
