paul55
Luxembourg
731 Posts |
Posted - 18/08/2023 : 16:34:37
Bit of a long shot I expect, but does anyone have or know where I can buy a set of Q type brake drums that are made out of the correct cast iron and actually work! Thanks, Paul |
2010 Posts |
Posted - 18/08/2023 : 21:07:27
Hello, Paul. It might be just as easy to get a set machined up from solid billets, choosing the correct grade of material, then you could include some nice cooling fins? Regards, Chris |
paul55
Luxembourg
731 Posts |
Posted - 20/08/2023 : 07:50:14
well that's one way Chris..could prove to be a tad expensive though! Thanks all the same! Paul |
Edited by - paul55 on 20/08/2023 07:50:54 |
3240 Posts |
Posted - 20/08/2023 : 09:59:41
I fitted Alfin drums to my L2, the braking was much improved. The drums are made by Typecast Ltd. I also think the drums look good on a Triple-M car. No connection, just a satisfied customer. George.
![](https://www.triple-mregister.org/forums//uploads/George Eagle/2023820105315_Alfin drum rear 2.JPG)
Edited by - George Eagle on 20/08/2023 10:53:22 |
paul55
Luxembourg
731 Posts |
Posted - 20/08/2023 : 11:20:07
thanks George, I'll check them out. Paul |
Posted - 20/08/2023 : 11:21:23
I believe that Tom Dark Engineering are able to supply new 12" brake drums to Q Type profile. I am interested in getting one set. Perhaps Tom could make a few sets if several of us are interested.
1940 Posts |
Posted - 20/08/2023 : 13:07:50
How does the Q profile differ from the regular profile? |
2010 Posts |
Posted - 20/08/2023 : 15:20:18
Hello, Paul. I can also recommend the drums mentioned by George but I thought you wanted the original Q pattern drums. Chris |
paul55
Luxembourg
731 Posts |
Posted - 20/08/2023 : 18:49:01
I do Chris, I was going to ask how much for Q type ones...keep everyone updated. |
paul55
Luxembourg
731 Posts |
Posted - 20/08/2023 : 18:50:38
just one thicker fin on the outer and inner edge...try to get a photo later. |
2010 Posts |
Posted - 20/08/2023 : 19:51:05
Original Q type drum, sorry it is not clearer. Chris
![](https://www.triple-mregister.org/forums//uploads/Westbury/2023820195049_3706ACA6-E7EF-4B3F-A7A5-3066FC155345.jpeg)
DK6780
249 Posts |
Posted - 20/08/2023 : 20:18:27
What was the original construction of these drums? At the same time Riley (and hence for ERA) manufactured their racing drums from Magnesium alloy ("electron") and shunk a cast iron liner into them with a limited number of radial set screws to avoid them slipping. This was also used by other manufacturers and makes a huge saving in unsprung weight (vs even a pressed steel drum). |
1940 Posts |
Posted - 20/08/2023 : 20:47:48
![](https://www.triple-mregister.org/forums//uploads/coracle/2023820204620_QDRUM-A.JPG)
2010 Posts |
Posted - 20/08/2023 : 21:00:12
Thanks, Nigel. I’m pretty sure these drums were made by Holden and Hunt and were a one piece drum, i.e.. no liner. They were also quite heavy which had the benefit of being very effective, I believe. Chris |
DK6780
249 Posts |
Posted - 20/08/2023 : 21:41:52
So very similar to these KN drums from a previous topic:
![](http://www.triple-mregister.org/forums/uploads/Andy%20Rogers/20145518_014%20X2X.JPG)
The rib towards the open side of the drum will go someway towards stopping it from dishing under heavy use, so may be more for that purpose than cooling. |
Edited by - DK6780 on 20/08/2023 21:46:16 |
2010 Posts |
Posted - 20/08/2023 : 23:42:54
Hello, Duncan. The KN drums were 13” and Q drums 12” otherwise identical. (Same maker) Chris
Note:- original drums were not supplied with the lightening holes! |
Edited by - Westbury on 20/08/2023 23:50:11 |
