Tim
75 Posts |
Posted - 17/10/2023 : 14:18:19
I am still looking for a J2 sump filter. Someone must have one on a shelf or in that oily old sump under the bench.
![](https://www.triple-mregister.org/forums//uploads/Tim/20231017141748_IMG_3059.jpeg)
3243 Posts |
Tim
75 Posts |
Posted - 17/10/2023 : 19:50:57
Thanks Lew but I’ve asked Rich and he said he doesn’t like to make them. That’s why I made the wider appeal. |
3243 Posts |
Posted - 18/10/2023 : 02:48:08
Not terribly hard to make them, IF (and that's a big IF) you can find or rescue the ends. I tried for months to locate the threaded end, but was finally given a PA filter which I lengthened into an NA filter.
Lew Palmer PA1169, NA0651 |
1936 Posts |
Posted - 18/10/2023 : 09:08:41
If P ends are the same as J, I may be able to help with a grotty P one. |
6122 Posts |
Posted - 18/10/2023 : 09:17:43
Is the gauze filter itself necessary if the engine has a full flow filter added?
3243 Posts |
Posted - 18/10/2023 : 15:01:53
From memory, the ends are the same. It's the length that varies. I used the ends from a J2 filter to build my NA filter.
1936 Posts |
Posted - 18/10/2023 : 15:28:57
Thanks Lew, I'll see what I can find. |
Tim
75 Posts |
Posted - 18/10/2023 : 18:36:03
The P type thread is much bigger than the J2 thread. |
3243 Posts |
Posted - 18/10/2023 : 19:13:35
Tim, you may be correct. I was only going by what I was told as to the origin of the filter I used. I assumed it was J2, but might have been P-type. All I know is that it fit after adding a 12 inch long core and gauze.
1936 Posts |
Posted - 18/10/2023 : 19:36:43
That's a shame; the thread is about 1 5/8" dia.
![](https://www.triple-mregister.org/forums//uploads/coracle/20231018193426_IMG_20231018_192724785.jpg)
Wouldn't want another "cross" thread. |
