chapelfarmer
242 Posts |
Posted - 06/02/2024 : 21:19:27
Has anyone got an up-and-running J2 engine that I could acquire in order to avoid what I expect might be an open-chequebook adventure? Thanks.
![](https://www.triple-mregister.org/forums//uploads/chapelfarmer/202426211852_IMG_5975.JPG)
john |
6168 Posts |
Posted - 06/02/2024 : 22:35:23
Ouch, indeed! Commiserations, John.
P.S. But didn’t you tell me you had a brand new crank sitting on top of the piano? Simon J J3437 |
Edited by - Simon Johnston on 06/02/2024 22:36:14 |
3114 Posts |
Posted - 06/02/2024 : 23:38:11
![](http://www.triple-mregister.org/forums/uploads/chapelfarmer/2018118103631_IMG_5180.jpg)
Surely that's it beside the sofa?
chapelfarmer
242 Posts |
Posted - 07/02/2024 : 07:22:26
Wow! I’ve heard of the Hive Mind but didn’t realise it included a Hive Memory…. Impressive archiving ! Yes I do have a steel crank but I’m conscious a) that installing it is unlikely to be a very ‘containable’ exercise b) that my block is M Type so not really correct (and I’m reluctant to dislodge / replace the head studs as they seem to work well) and c) that the funny cooling arrangement I mentioned in another post is hard to understand. Blanked off waterways on the inlet side of the block face. Again, this has worked fine so I don’t want to change it. All in all, this engine has worked well as a piece but is it a good basis for a new and maybe expensive one? It may be better / cheaper / easier to find a good J2 engine, drop it in and sell all these bits (now dismantled). Of course the good J2 engine referred to is probably hidden under a pile of straw somewhere in a unicorn stable, but I thought I’d ask! John
john |
Sr537
31 Posts |
Posted - 07/02/2024 : 09:12:35
Look on vintage mg parts .com one for sale just now. |
chapelfarmer
242 Posts |
Posted - 07/02/2024 : 10:46:38
Thanks Sr537 but I can't see that. Is it on their website?
john |
Michael Lees
171 Posts |
Posted - 07/02/2024 : 11:24:11
On Facebook
Mike Lees 1935 NB (NA0897) |
3248 Posts |
njnh
405 Posts |
Posted - 08/02/2024 : 09:28:11
John, have you thought about replacing just the crank and rods using original parts? I have a spare original crank and matching rods which are very good and wouldn't need any work. You are welcome to have them.
Nigel H |
3114 Posts |
Posted - 08/02/2024 : 11:51:45
Replacing the broken crank with the new one and using P-type con rods (someone might even give you a set) would seem like a very cost effective solution.
2165 Posts |
Posted - 08/02/2024 : 21:58:51
But adding P rods to an old bent wire crank increases the inertia weight on an already weak 90 year old crank. Many blocks have been written off through chancing an old crank. There is only one way to do it properly.
Ken Robinson has a newly built high spec engine sat on his bench at the moment and it will be offered for sale. However, do not expect it to be a cheap price, in fact take a glass of brandy to drink if enquiring but, it’s reflective of a top quality build, including large cam conversion
6168 Posts |
Posted - 08/02/2024 : 22:19:12
Rich, I think Sam was suggesting using P Type rods on the new crank pictured above, not on a replacement original which would, in any event have 1 1/2” journals compared to the 1 5/8” ones of a P Type.
JohnE
377 Posts |
Posted - 09/02/2024 : 12:48:40
Richard, have you checked the price of a good Brandy this year.![](images/icon_smile_big.gif)
JohnE |
1972 Posts |
Posted - 09/02/2024 : 13:26:38
quote: Originally posted by JohnE
Richard, have you checked the price of a good Brandy this year.![](images/icon_smile_big.gif) JohnE
Perhaps a "bullet proof" Scotch would be better?
![](https://www.triple-mregister.org/forums//uploads/coracle/20242913260_IMG_20240209_132218640_BURST004.jpg)
Nick Dean
444 Posts |
Posted - 09/02/2024 : 20:22:37
Broken Cranks also make very good table lamps. Nick.
N A Dean |
spindlyspokes
16 Posts |
Posted - 08/04/2024 : 21:14:34
A full counter balanced solid steel crank and 4 beautiful con rods made to a 76 mm stroke with shell bearings the rods have a 45 split like the 1100 cc BL setup. The crank flange has 8 holes for flywheel. All marked USSR . |
