Rob34
21 Posts |
Posted - 19/10/2015 : 22:26:16
I'm in need of the reduction box to attach the speedometer cable to the transmission for L0280. Any help or suggestions would be appreciated. |
3247 Posts |
Posted - 19/10/2015 : 22:46:14
Rob, Is it really a "reduction" box on the L-type? I'm not very familiar with the L-types, but on most Triple-M cars, it's simply a right angle drive. Here in North America, Ian Marr (farley1 on the Forum) makes them.
Rob34
21 Posts |
Posted - 20/10/2015 : 02:41:58
I was thinking it was just a 90 degree angle drive myself but got word today from Barry Walker that it had a 100:143 ratio. Perhaps other L Type owners could chime in. |
PeteF
66 Posts |
Posted - 20/10/2015 : 02:55:07
There's no reduction box on my L1. In fact it doesn't have the angle drive either. It seems to work OK though.
Pete L1, PA, TC |
treetops
284 Posts |
Posted - 20/10/2015 : 07:07:17
Rob,
Barry Walker is right.There is a reduction box on the L type.. Jos ex L2086 NA 0386 |
sven
Sweden
434 Posts |
Posted - 20/10/2015 : 07:13:38
Agree with Jos and Barry Walker
Sven L2039 and L0671 |
sven
Sweden
434 Posts |
Posted - 20/10/2015 : 07:51:47
Sorryy, ment to say that it also has no angle drive the 100:143 is a straight reduction box wheree the in and out shafts rotate at the same direction. There are other boxes out there which also reverse the drive. Good luck Sven |
Rob34
21 Posts |
Posted - 20/10/2015 : 16:19:50
Thanks for the comments gentlemen. Looks like I will be on the hunt for one of these. Cheers. Rob |
3392 Posts |
Posted - 21/10/2015 : 16:33:51
Oliver Richardson sent me this picture of an original reduction gearbox which may help you in your search
Rob34
21 Posts |
Posted - 21/10/2015 : 19:18:18
Thanks! The hunt continues.... |
3247 Posts |
Posted - 22/10/2015 : 00:37:14
Some years ago (2003), Chris Nowlan mentioned he got a nice, but pricey, repro reduction box from David Naylor.
947 Posts |
Posted - 22/10/2015 : 07:56:56
That image looks awfully like the reduction box on the later 'T' series cars. Is it possible to check these ratios, and if not appropriate to open one up and substitute for a better set?
Ian Bowers OD 6791 J3 3772 |
tonym
654 Posts |
Posted - 22/10/2015 : 15:03:54
Also to be found on VA's as well [& probably SA's & WA's] |
761 Posts |
Posted - 22/10/2015 : 21:37:55
I think the T type ones have a ratio of 2.25, I had one on my 18/80 which made the speedo read about 20% slow. It looked like the one in Oliver's picture above.
John Cooper |
Edited by - Cooperman on 22/10/2015 21:39:29 |
Bodger
65 Posts |
Rob34
21 Posts |
Posted - 26/10/2015 : 11:23:01
Thanks for the lead Bodger. I'll follow up if successful. Rob |
