Tim Burton
29 Posts |
Posted - 27/02/2018 : 11:56:25
I am trying to find a new old stock crankshaft bearing (RHP QJM) to buy for my M type, other engine parts, old or new, would also be of interest for my engine rebuild.Thanks for any assistance in this.
T.Burton |
ja.mcnab
204 Posts |
Posted - 27/02/2018 : 12:56:53
I have front housing, crank flange and bronze sleeve, clutch drive and cover plates, complete J2 flywheel and clutch( good for M as larger driven plate ), various oil pipes etc. What do you need? |
gsrun
180 Posts |
Posted - 27/02/2018 : 12:58:33
Is this the one you need? Graham
contact direct gsrun@rocketmail.com if of use
![](http://www.triple-mregister.org/forums/uploads/gsrun/2018227125748_001.JPG) |
Malcolm Eades
379 Posts |
Posted - 27/02/2018 : 14:27:16
You really need the split race type to take the side thrust. See:
www.triple-mregister.org/forums/topic.asp?ARCHIVE=true&TOPIC_ID=8185&SearchTerms=RHP,QJM
As stated in that thread, there is a modern near equivalent which I got from vintagebearings.co.uk but be prepared for a sharp intake of breath when you hear the price. Depending on your housing, you may find it a tad loose, for which the orthodox solution is to build up the outer race with chrome plating, However, one of the locking fluids might work.
Malcolm M Type
Edited by - Malcolm Eades on 27/02/2018 14:28:18 |
2162 Posts |
Posted - 27/02/2018 : 20:34:54
The RHP JM needs more balls! The split track RHP QJM 1 3/8th has 10 balls from memory and is a lot harder wearing. You can also adjust it with it being split inner track.
The original early J crank bearing was a double race with significantly more balls and better still, but not been around for many decades sadly
RHP do make new QJM 1 3/8th bearings although very expensive. Chinese copies are around and are garbage material ( sometimes come in a plain blue box).
Edited by - Richard Hardy on 27/02/2018 20:35:29 |
2162 Posts |
Posted - 27/02/2018 : 20:35:42
RHOP do make new QJM 1 3/8th bearings although very expensive. Chinese copies are around and are garbage material ( sometimes come in a plain blue box).
SV4670
303 Posts |
Posted - 28/02/2018 : 08:46:49
If you want a Phoenix crank and rods S and V can supply you. I am hoping to swap astandard M type Phoenix crank for a fully counterbalanced J type crank |
