 PB Front Apron - 1/4" BSF Dome Nut
cook
Posted - 29/04/2019 :  15:19:18  Show Profile
I am looking for a supplier of the 1/4" BSF Chrome Dome Nut and Washer and 1/4"BSF x 5/8" long Black Bolt that secures the Front Apron to the MG PB Dumb Irons. Any ideas ?
ICook
Posted - 29/04/2019 :  18:55:43  Show Profile
Hello Ian and a warm welcome to the Forum. I know we have already had contact about your M type but do you also have a PB? If so, your ownership has escaped us! Could you please (as they say) 'fill us in'?
PS to answer your question, I have lost any number of these nuts from the front apron of my PA, so nowadays resort to aero nuts, which tend to hang on for a bit longer!
Thanks and best wishes
Edited by - DickMorbey on 29/04/2019 18:57:05
Posted - 29/04/2019 :  20:47:33  Show Profile
Ian,
Another alternative would be to use stainless steel plus a bit of polishing and use a lock/half nut to prevent loosening - plus s/s bolt/set screw and washer - 4 off each required:
Another supplier : https://www.polished-stainless.com
Bruce. (PB0564)
Edited by - Bruce Sutherland on 29/04/2019 21:15:50
cook
Posted - 30/04/2019 :  18:06:05  Show Profile
Hi, Thanks for the replies. I am trying to MATCH my existing PB front apron 1/4" BSF Set Screw fixings. As you all know, there are four. I have lost one unit. Therefore I only require one at present. The existing 1/4" BSF Set Screw units each comprise 1 x 5/8" Long 1/2" Black (or BZP) A/F Set Screw: 1 x 9/16" O/D x 1/32" Thick BZP Washer and 1 x 3/8" High x 7/16" A/F Chrome Dome Nut. I think that I have now found a supplier called "Namrick Nuts & Bolts. Tel: 01273-734963. I will probably get some spares when their stock order arrives.
ICook
