cardiffrob
100 Posts |
Posted - 07/05/2012 : 20:20:08
I have a one-off car that uses Wolseley axles and I need a pair of rear splined hubs to build up another axle casing for when mine gets taken apart for rebuild. I don't need the shafts but would welcome a set of hubs, even if worn, so long as they will pass an M.O.T test. I'm in Cardiff but travel around a bit.
Other bits I could do with finding include a set of 4 Hartfords of the type used on the front of the P types, a front axle beam for a pre-war Morris Minor and a useable engine for the same.
Any suggestions would be most welcomed.
Rob |
BRIANW0454
18 Posts |
Posted - 08/05/2012 : 11:09:19
I have a pair of good rear hubs one with a shaft and one without.
Brian |
cardiffrob
100 Posts |
Posted - 08/05/2012 : 12:44:13
Thanks, Brian. 3 questions, whre are you, how much and if you are far away would you be able to post them? I may also need a pair of rear spinner nuts if the ones on the current axle are a different thread. Unlikely, but you never know! |
3682 Posts |
Posted - 08/05/2012 : 13:14:10
Hello Rob. I can answer the first of your questions - Ashton under Lyme - which is shown when you click on Brian's profile
Dick Morbey PA/PB 0743 Henley-on-Thames, Oxon, UK |
Edited by - DickMorbey on 08/05/2012 13:15:03 |
BRIANW0454
18 Posts |
Posted - 08/05/2012 : 13:16:19
Rob can you give me a ring on 01782 768411 and we can sort them out.
Brian |
BRIANW0454
18 Posts |
Posted - 08/05/2012 : 13:20:03
Hello Dick it would seem that I have to change my profile it should be Newcastle-under-Lyme.
Brian
3682 Posts |
Posted - 08/05/2012 : 13:52:01
Sorry Brian - my error - nothing wrong with your profile!
cardiffrob
100 Posts |
Posted - 08/05/2012 : 15:55:51
Dick Morbey ... Hmmmmmmmm ... that name rings a bell. Did I buy either a P body or a P windscreen off of you about 15 years ago????
Small world, innit! |
3682 Posts |
Posted - 08/05/2012 : 17:08:31
Yes Rob, you did indeed - the body, at least! What became of it? Is it on the one off car mentioned in this posting?
Would love to see some pics!
McEvoy
252 Posts |
Posted - 09/05/2012 : 22:09:54
Hi Rob, I have an M Type front axle beam that I believe is the same as a Minor one. Any experts please advise if this is not the case.
Bob |
cardiffrob
100 Posts |
Posted - 10/05/2012 : 14:17:22
The body has been 'off' due to us moving house last year. Meanwhile, can anyone guess where this rad shell came from???
Bob. That would be the same as the Minor, I'm fairly sure. I currently have a Morris 8 beam which is about 3 inches wider and this affects the bowdenex cable brakes quite a lot. The original beam had rusted out across the front with deep pitting. Not worth trying to use it. Any idea what it is worth? |
Edited by - cardiffrob on 10/05/2012 14:22:05 |
3682 Posts |
Posted - 10/05/2012 : 14:50:41
Y type rad maybe?
cardiffrob
100 Posts |
Posted - 10/05/2012 : 16:34:22
Close. The shell was hand made by the chap who taught me to use the English Wheel. He copied the inner dimensions of a Y but made the front flatter for me, more like an earlier car. The bottom of it shows the flatness. He did it this way to allow me to use a Y radiator. Cost me a slab of St Miguel beers! The chroming was done down in Dorset and it was only after I got it back that I realised I'd forgotten to ask for him to add the hole for the starter handle. I never did get round to having the extra bit chromed.
Easier to see in this earlier pic
Edited by - cardiffrob on 10/05/2012 16:54:48 |
cardiffrob
100 Posts |
Posted - 01/07/2012 : 13:02:25
Brian. No great hurry but I'd like to buy those rear hubs off you if you still have them. Will your friend still be able to pop the shaft out of the hub for ease of postage? Cheers Rob |
BRIANW0454
18 Posts |
Posted - 02/07/2012 : 13:27:02
Rob Only one nearside one left give me a ring if you still want it without shaft.
Brian |
cardiffrob
100 Posts |
Posted - 02/07/2012 : 15:30:15
Aaaaaargh! I'll still need a pair eventually. Mind if I keep hunting for a while, Brian? |
