Bill Putnam
64 Posts |
Posted - 30/10/2023 : 13:40:12
Greetings,
Am looking for L type clutch disk centres. This is for the twin plate L type clutch. Sports & Vintage Motors say they don't have any nor have any plans at this time to make up a batch.
If anyone has access to a broach we can turn new centres on a lathe, but need to have a broach to form the internal spline.
Photos of an original set as well as a worn centre attached.
Thank you,
Bill
![](https://www.triple-mregister.org/forums//uploads/Bill Putnam/20231030133813_L_Clutch_disks.JPG)
![](https://www.triple-mregister.org/forums//uploads/Bill Putnam/20231030133854_L_Clutch_Centre.JPG)
bputnam@cityofmadison.com |
Moth eaten
946 Posts |
Posted - 31/10/2023 : 08:10:34
Bill these are the 2 friction plates, I had new ones laser cut, and have one new centre and one good original. Also I have new round/dome head steel rivets I obtained from the UK. The issue with the rivets is you'll have to make a punch and mandrel to fit, the head dia is 9.68mm. Cant help you with the broach unfortunately.
N.D.Willey |
Edited by - Moth eaten on 31/10/2023 08:13:53 |
1935 Posts |
1935 Posts |
Posted - 31/10/2023 : 14:57:08
I have found a J clutch plate (I think) when rummaging about which might be of use to you. I don't know if it is a suitable substitute for one of the L type plates.
The splines are fine and the disk itself has been replaced some time ago. The disk is 7 1/4" overall diameter.
I bought it in anticipation of needing the splined centre but subsequently managed to satisfy my need by other means so it is now surplus to my requirements.
![](https://www.triple-mregister.org/forums//uploads/coracle/20231031145524_Jplate4.jpg)
Bill Putnam
64 Posts |
Posted - 06/11/2023 : 14:03:31
Thanks for everyone's posts.
The J2 centre profile does not work with the L type double plate design, unfortunately. Will look more into using a lathe or mill to cut the internal splines-have access to both as well as a dividing head. Already have rivets, punch and mandrel-have replaced the centre on J2 disks several times.
Best wishes,
Bill Putnam
2159 Posts |
Posted - 06/11/2023 : 19:20:17
Nigel, it is possible to broach on the lathe but the lathe will not thank you for such punishment! It is far more preferable using a slotting head on the mil.
Edited by - Richard Hardy on 06/11/2023 19:21:33 |
Hornet
382 Posts |
Posted - 06/11/2023 : 21:39:42
very simple job to slot them with a slotter , or slotting head on a mill , I made tooling to slot these many years ago and its pretty simple . any decent mach shop should be able to do this |
Bill Putnam
64 Posts |
Posted - 14/12/2023 : 16:37:56
New centres have been found, thanks to all who responded. Best wishes and Safety Fast, Bill
