Thought this would be easy in the UK. I have a few here in Aus if you are up for the postage. Have black , brown , brass ring ( suit your SA) and even one that says OFF. What is a switch that says OFF used for apart from the obvious ?
Well thanks very much for the offer Stuart but if past experience is anything to go by, postage from Australia to the UK is an arm and a leg. But frighten me. I'm not at all sure what OFF means unless the very strict Australian code of ethics has resulted in the instruction being part-censored.Or perhaps they came in pairs and one is missing? Nor am I sure even that OFF is correct for my application. As it is a panel light switch, PL seems more appropriate but I have seen both.
