Dear MMM friends I am looking for a T-shaped rubber seal for the lower side of the windscreen of my J2. Unfortunately my search has been unsuccessful. Does anyone know a supplier for the rubber seal?
Lew, do you know of anyone who supplies a "softer rubber" version than the usual versions (e.g. Moss Motors), that would allow an "easier to fold" windscreen?
Thanks for the link. I think it should be a T-profile for a good mounting. I measured the height of the profile at about 60mm. But the profile could be a little less thick. Now it is about 2.5 mm thick. I looked on Sealdirect beforehand and didn't find anything 1:1 fitting.
Thomas, perhaps I misunderstood the windscreen seal you wanted, if it was that between the lower cross-member of the windscreen frame to the body scuttle panel then this may be what you require: https://www.sealsdirect.co.uk/shop/atmg1964-21517?category=540
You can search through all the different seals which this company has.
Bruce. (PB0564)
Edited by - Bruce Sutherland on 10/12/2023 21:45:51
