Looking for mid 30s Lucas tandem wiper arms and linkages for centre-drive system,(central screen-top mounted motor). Also need pivot shafts in screen. Condition unimportant as required as pattern to remake.Lucas system preferred but anything similar considered.
Thanks Simon but it's not that type. The wiper arm is secured to the idler shaft by means of a stainless steel trunnion and clamping screw.I believe there is a lever a couple of inches long that attaches to this trunnion and is mounted above the wiper arm.The linkage attaches to the lower end of the lever.
Angus I think the one you are showing from the Lucas catalogue is the same as the ones pictured below. Used without an external link on Tickfords and saloons with driven wiper shafts. The broken one with provision for an external link may be the kind you are after. Merry Christmas from AUS.
To me Stuart, Gus's illustration, apart from the drive being in the centre as opposed to in the "passenger killing" position, is the same as those on the P Type:
Thanks to all for the info. Stuart, the arm you show is of course Lucas but it seems they had a number of designs and this is not the one I need - but thanks for the pic. Your P type illustration looks identical Dave. Much appreciated. Are you able to find some good detail pics of the component parts or better does anyone have any surplus parts? Gus
