Does anyone have a couple of surplus shims for the sector shaft cover plate? This is the cover plate with 3 studs, not the end plate. A 5 thou and 10 thou shim would be perfect.
Hi Nigel, May be I can bring help. But if you can get them from a UK member is far more easier because of the difficulty to get parts from Europe to your address. Brexit, thank you. Best regards. Pim
Why don't you make them from aluminium foil? You can buy some 150mm x 150mm 40 micron (1.6thou) hookah foil, 50 sheets for about £13.00 on ebay So you'd need 3 for 5 thou and 6 for 10. You can cut out direct from the steering box housing using a ball pein hammer. Very easy and with multiple shims you can get the exact thickness you need.
Thank you for the suggestion Angus, but I would prefer to use a couple of shims rather than multiple layers.
Pim - thank you for your offer. I will hang on for a few days and, if no further replies, I will get back to you. Just a thought - would it be possible to post the shims to the UK inside a New Year greeting card in the usual way?
