henderson
72 Posts |
Posted - 30/03/2013 : 17:03:42
I am coming to the end of my L1 (4 seat) Restoration . Can someone shed some light on what seats are right for the Car. Please see attach photos of the original front seats which have been with the car for over 40years.
However all the L1 front seat are bucket seats and in a way my seats are, but the top rolls back and are more square across the top .
As you know bucket seats are more Gothic type if you know what I mean.
![](http://www.triple-mregister.org/forums/uploads/henderson/201333017_SAM_0309.JPG)
![](http://www.triple-mregister.org/forums/uploads/henderson/201333017_SAM_0304.JPG)
![](http://www.triple-mregister.org/forums/uploads/henderson/201333017_SAM_0299.JPG)
![](http://www.triple-mregister.org/forums/uploads/henderson/201333017_SAM_0296.JPG) |
3240 Posts |
Posted - 30/03/2013 : 20:31:54
Hi Colin
To me the seats do not look original to an MG, it looks as if the bases would be too wide to fit as they do not have the cut out for the transmission tunnel.
Also I believe the backs would be straight rather than what you describe as rolled back. Also the seats would need to be hinged to allow the rear seat passengers to gain entry. Finally I think you would end up sitting too high with those runners fitted.
George L2023 andNA0960 |
henderson
72 Posts |
Posted - 30/03/2013 : 22:38:57
Thanks George
The seats do fit between the transmission tunnel and the passenger seat is hinged to allow passengers to gain entry to back, if you look at the photo I have a cut away hinge. Will double check the high .
However that`s the problem there do fit and look o`k ??? Colin
Moth eaten
946 Posts |
Posted - 30/03/2013 : 23:36:59
See attached. Both my seats have lost their original rails the 2 strips with holes are later, and the passengers has 2 hinges that look like they came off a Tiger Tank. I believe the buckets are original. Dimensions are: Width 15" base length 19" height 23 3/4".
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/201333023_GEDC3255.JPG)
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/201333023_GEDC3257.JPG)
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/201333023_GEDC3258.JPG)
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/201333023_GEDC3259.JPG)
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/201333023_GEDC3260.JPG)
N.D.Willey |
Edited by - Moth eaten on 30/03/2013 23:38:28 |
henderson
72 Posts |
Posted - 31/03/2013 : 00:07:07
Thanks for that, I see yours do have a slight cut out to go around the tunnel. Your bucket seats are more Gothic at the top.If any consolation I have a bit of wood worm instead moth eaton. Colin |
sven
Sweden
431 Posts |
Posted - 31/03/2013 : 06:47:36
My L 1 seats look as those on moth eaten's pictures and only the pasenger one is tippable. I have had the car since 1965 so I am pretty certain they are as original.
All the best Sven |
Moth eaten
946 Posts |
Posted - 31/03/2013 : 06:56:23
Hi Colin We call wood worm BORER in Australia. I am glad I helped with the images. Your seats certainly look old, you might be able to re shape them.? I used moth eaten as the carpets in my L1 are well dined on by those little flying invaders! I rather like patina, a contrast to over restored cars! A matter of choice of course! Cheers Nigel
N.D.Willey |
Moth eaten
946 Posts |
Posted - 31/03/2013 : 07:17:06
I am not 100% sure about this method of fixing with bolts through the floor for the driver, you have to get underneath to release the nut! surely not correct? and the hinged passengers. Does anyone have the same method of securing their seats in an L1 ? Barry Walker said they had rails.
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/20133317_GEDC3267.JPG)
![](http://www.triple-mregister.org/forums/uploads/Moth eaten/20133317_GEDC3268.JPG)
N.D.Willey |
3240 Posts |
Posted - 31/03/2013 : 20:43:14
Hi Nigel
Your seats certainly look original to me although I have never had any experience of L1s.
If you have some flat bar you could drill and tap holes to match those on the seat securing hinges and then fix them to the underside of the floor boards - this would do away with the need for nuts.
George L2023 and NA0960 |
sven
Sweden
431 Posts |
Posted - 31/03/2013 : 21:16:59
Same type of mounting as shown in the pictures on my L tourer Sven |
Moth eaten
946 Posts |
Posted - 31/03/2013 : 22:39:59
Hi George I was wrong my seats and their method of fixing is correct and as originally fitted. Everything about the 2 seats is old well patinated and obviously made by MG or their supplier. Its certainly bone shattering stuff, my only question is did they have a wooden base or thin sandwich of wood under ea originally, as bolting the metal base of ea seat pan straight onto the carpet looks strange. John Firth Smith who prev owned AGW666 sent me this info.The early bench seats in D,J.F2.L2 .PA,PB etc had flat bars with round pegs screwed to the back of the seat that fitted into flat bars screwed to the floorboards with a row of holes and a number of wooden 1/2 x 1/2 bars screwed to the floorboards to stop the bases moveing forward very simple. On the L1 the drivers seat (from memory) the adjustment is by moving the bolts in the slots in the seat bases or floorboards. Kind regards Nigel
N.D.Willey |
Edited by - Moth eaten on 31/03/2013 22:40:54 |
henderson
72 Posts |
Posted - 31/03/2013 : 22:46:04
Thanks Nigal for the pictures,great help
If you look at the 2nd picture from the top , I do have the same hinges as yours passenger side. I am happy to use the runners as shown in 2nd picture. I must say if you look at Malcolm Green book Volume Two, the seat do show on page 43 Gothic at the top.
I wonder if my seats are from a Morris of that year ? . |
1723 Posts |
Posted - 01/04/2013 : 10:31:30
And here are another style, apparently J4 but similar to the ones in Tim Edwards' salonette.
P
![](http://www.triple-mregister.org/forums/uploads/PeterL/20134110_seats.JPG) |
henderson
72 Posts |
Posted - 01/04/2013 : 13:31:02
Thanks Peter.
Looking at yours and Nigel seats, both are the similar shape and as George said I should have a bit of a cut out for the transmission tunnel. However they do fit in the car, but I have to say Nigel seats do look good and comfortable.
May be it`s down to new set of seats like Peter`s and Nigel.
May I say thanks to you all for your pictures and help. Maybe I should get both set`s made up and change them over ,that would be a good talking point at a meet ?
Colin |
1682 Posts |
Posted - 02/04/2013 : 00:15:59
Colin,
I am no L1 expert but could L1's have been fitted with more than one type of front seat? The picture below was taken in the early 1970's and the front seats look the same as yours.
![](http://www.triple-mregister.org/forums/uploads/Peter Green/2013420_L10001.jpg)
Peter. |
3243 Posts |
Posted - 02/04/2013 : 03:16:57
Peter,
That L1 in your posted photo is the car previously owned by Nick Sands and pictured in River Fletcher's book. It was purchased by Bob Figenskau in the early 1980's (my best man at my wedding). It was sold to a purchaser in Germany but has been seen on this website as being for sale again a couple of years ago. It sure brings back some memories of running around Grand Rapids, Michigan in 1994 when attending a John Twist Summer Party.
