6140 Posts |
Posted - 28/05/2014 : 18:09:19
There have been a few discussions on the Forum over the years on how best to ensure that we can be seen on the roads in darkness. Rear lights and indicators on either side of a low set number plate don't make us readily visible to other drivers who nowadays expect to see rear lights and indicators at eye level, or close to it.
So one of the jobs I had done over the winter was to mount the rear lights on the rear wing stays of the J2. Gerard van Puten had some brackets available on his web site but at my request he modified them a little (see item number 19 at http://www.mgmmm.com/parts.htm for the revised version) and the resulting location is, to my mind, very neat.
As you can see, Oliver Richardson did a very neat job of installing them and ran the wiring behind the tank so that it looks like an original installation.
Being a J2, it seemed appropriate to paint them the same as the headlights and side lights. For the single number plate light I used the repro of the Lucas MT 211 light. It's slightly shorter than the original Lucas TF 201A, but it looks pretty good I reckon and at about 17 quid on fleaBay a lot cheaper than the genuine article!
I have LED conversions in all the rear lights, and the front side lights as well, which provide a strong bright light with minimal battery drain. I got these from Peter Jury ( www.dynamoregulatorconversions.com ). In fact I needed to replace the existing LED bulbs in the front side lights which I had got from another supplier but which didn't work properly (the side lights went out when the engine was started!) and Peter had a replacement pair of bulbs with me the next day to ensure that I had them for the Triple M event in Scotland. (No connection with either Gerard or Peter other than as a very satisfied customer)
Edited by - Simon Johnston on 28/05/2014 18:29:10 |
Max Headroom
292 Posts |
Posted - 28/05/2014 : 23:04:54
Nice job Simon!
Having seen the back of a very dimly lit old Rolls Royce with low-mounted lights in very bad weather on the motorway one night, and seen for myself the potentially serious implications, I have often pondered this problem.
Personally I am reluctant to change the look of my car, and if I ever do get it on the road, thought I might simply clip LED bicycle lights onto similar areas of the back of the car. Some of those LED bike lights are small but very visible, and battery life lasts for hours and hours, but they could easily be removed for the 'correct look' during the daytime. Yes it might be a bit of a hassle but I think I could live with it. Nevertheless I think you have a very good 'permanent solution' and it does look very nicely done.
This has certainly given me some more ideas to consider!
Light travels faster than sound. This is why some people appear bright until you hear them speak. ________________________________________________________________________
6140 Posts |
Posted - 29/05/2014 : 05:36:50
Mark,
The battery LED lights are certainly an option, but wouldn't solve the problem of more clearly visible indicators which I feel are an absolute necessity in modern traffic.
Max Headroom
292 Posts |
Posted - 29/05/2014 : 10:48:14
I'm still considering the indicators problem .
I've thought about fitting a bicycle indicator and brake-light unit to the top of the wheel carrier but wonder if this might just cause confusion. It also looks a bit too modern.
Looking further at a removable solution, another consideration might be using a set of smoked-lens motorbike-fairing indicators strapped to the sides of the spare tyre, with a quick-release plug/socket for reverting to it's 'period' look.
Years ago I was riding motorbikes, time-cancelling indicators with a loud audible warning became common, but are seldom seen/heard these days. The audible 'beeping' reduces the chance of an indicator being inadvertently left on - potentially lethal for a motorcyclist. Even in a modern open car, with more (sun)light on the instrument panel warning lights it is easy to leave the indicator on, and I've had this happen under certain conditions where the self cancellation has not had a chance to reset.
It seems that the front indicators can be inside Lucas 1130 type sidelights and are easily available - a neat idea!
Your more 'permanent' solution for the back lights has certainly given me food for thought and making me question having the lights removable at all! The thought process continues...
Either way, with modern traffic conditions, I completely agree that I'd want to be lit up like a Christmas tree in a much slower car!
Edited by - Max Headroom on 29/05/2014 10:54:45 |
6140 Posts |
Posted - 29/05/2014 : 11:03:25
The thing about the way I've located the lights is that it would have been perfectly possible to have had the same set up in 1933, bar the flashing amber indicators of course. I had been thinking of using smoke lens paint to disguise the amber lenses and may well try that in the coming months. I've also been thinking about a time controlled relay as it is all too easy to leave the indicators flashing.
As for front side lights, if you have the double contact lamp units wired for flashing indicators then LED bulbs that fit straight in and give you white side lights and amber indicators can be found here - http://www.dynamoregulatorconversions.com/combined-side-and-indicator-bulbs-shop.php Again, no connection with the company; just a satisfied customer
BobH
250 Posts |
Posted - 02/06/2014 : 23:40:50
A bit late on this topic (and first ever post). I recently fitted LED indicator boards to the pork-pie lamps on my M type. The original glass lens was too dark for the amber LED to show through properly so I had to fit the supplied plastic replacements. I thought the orange section on these looked wrong so I sprayed it with red Rustoleum stained-glass paint, which is transparent. Now in normal light the lens looks all-red but when operating the orange indicator shows through a treat.
Bob Howden |
6140 Posts |
Posted - 03/06/2014 : 05:55:59
Bob,
I had been thinking of trying the smoked lens paint as the amber flasher shows as amber through it. Does the amber flasher show as amber through the red glass paint?
Posted - 03/06/2014 : 08:00:14
Welcome to the Forum, Bob and thanks for your ingenious suggestion.
BobH
250 Posts |
Posted - 03/06/2014 : 17:04:03
Simon - yes the red stained-glass paint is pretty transparent and the flashers just shine through orange as normal. I couldn't see much light loss either. It just required a coat or two of the paint on the outside of the lens which is enough to make them look red under normal daylight. I did not paint the inside - picture attached (I hope)
6140 Posts |
Posted - 03/06/2014 : 18:59:35
Bob,
That was an excellent find and I shall pop down to Homebase (who seem to stock this paint) to get some and give it a go.
Many thanks.
942 Posts |
Posted - 03/06/2014 : 19:07:34
If they don't stock it, then we do!
Deka Glass Paints
www.georgeweil.com
Ian Bowers OD 6791 J3 3772 |
leafrancis14
323 Posts |
Posted - 03/06/2014 : 19:43:50
Regarding the turn signal warning buzzer, I've fitted something like this http://www.maplin.co.uk/p/high-power-buzzer-fk84f
It's wired in parallel to the warning light and is so loud that I quietened it a bit with a piece of tape....but there's no way even someone a bit deaf like me will forget to cancel the signal.
Barny Creaser
(Wellingborough) |
Max Headroom
292 Posts |
Posted - 03/06/2014 : 23:55:00
Barny Creaser
(Wellingborough)
I seriously believe this is a good safety feature - interesting that you did this Barny - ex biker by chance?
leafrancis14
323 Posts |
Posted - 04/06/2014 : 07:55:29
Yes I am....personally I think this is safety critical when retro fitting non cancelling winkers as sooner or later you will forget to cancel them.
Barny Creaser
(Wellingborough) |
1474 Posts |
Posted - 04/06/2014 : 08:10:34
I like the buzzer idea. Thanks.
Ian |
6140 Posts |
Posted - 04/06/2014 : 09:32:06
I've just ordered this item on fleaBay - http://www.ebay.co.uk/itm/251337237605
The buzzer doesn't come on until after a pre-set number of flashes or seconds, and, by connecting it to the stop light switch, it can be silenced by applying the foot brake if waiting for a lengthy period at a junction with the indicators going. Once the brakes are released the buzzer comes into action again.
I haven't actually tried it yet but plan to fit it on my next trip home.
