John James
963 Posts |
Posted - 30/11/2013 : 19:34:42
This chap seems happy with his lot as he drives along sucking on his pipe. What car is he driving, please?
![](http://www.triple-mregister.org/forums/uploads/John James/2013113019_scan0006.jpg) |
3237 Posts |
Posted - 30/11/2013 : 20:30:45
Hi John
Looks like a much modified Austin seven to me?
The front has been modified to take telescopic shock absorbers and the windscreen looks as if it came off something like a Singer?
Perhaps our trials experts can identify the car by the Registration number.
George L2023 |
John James
963 Posts |
Posted - 30/11/2013 : 22:42:28
Thank you George. Having looked into this further I see that the registration mark was issued from 1938. A Singer Special perhaps, anybody? |
Bob Stringfield
854 Posts |
Posted - 30/11/2013 : 23:12:59
EOG is 1938. The car is, as George says, likely to be an Austin 7 Special which may well have been constructed on a '38 Austin Ruby chassis, though, judging by the driver's dress, the picture was taken in an era when, shall we say, A7 numbers were not necessarily with their original chassis.
It could have an LMB front axle, common enough in that era.
A better place would be on the Seeking Information thread.
Bob. |
Edited by - Bob Stringfield on 30/11/2013 23:14:05 |
Robin Macmillan
415 Posts |
Posted - 30/11/2013 : 23:28:35
EOC not EOG methinks .... A7....circa 1966-1971...spring/summer..of love
PB 0527 |
3372 Posts |
Posted - 01/12/2013 : 01:24:54
Bob Agreed. Here it is. Nick
David R
289 Posts |
Posted - 01/12/2013 : 20:41:46
Looks mainly Austin 7 to me,and a typical Special probably 1950/60s The registration number would not date the car but merely indicate the main source of parts. It could,however,be a genuine Austin Nippy or Type 65 that has been modified because the rear end and rear wings do not look correct,and the windscreen is definately wrong. The chrome radiator surround is pre-Ruby and of the type fitted to pre-1935 cars,saloons and open cars. The headlamps are later and look to be Lucas 700 type.
Cannot help on the substance smoked. Could be 4 Square Yellow as smoked by my Dad in his pipe.
David R
(J 3355 and Austin 7 RP Saloon) |
3372 Posts |
Posted - 01/12/2013 : 22:23:06
John If the quality of the picture is good enough you might be able to read the date on the tax disc that might help. Nick |
1529 Posts |
Posted - 02/12/2013 : 07:40:08
Methinks 'tis a 'Cambridge' special.
Roger Thomas used to (still does?) operate from the old Cambridge Engineering premises.
They used to make Austin 7 tuning accessories and replacement bodywork. There have been some ghastly Austin 7 special bodies but the Cambridge offering was quite pretty and quite reminiscent of 2 seater MGs of the the we are familiar with. If you look carefully at the photo you can make out the humped scuttle through the windscreen.
How do I know? Well, I used to own such a machine. My brother rescued it from a field near his school and ownership subsequently passed to me. I did a virtual rebuild on it. Oddly, the car had Morris 8 engine and gearbox which went surprisingly well until it threw a rod one day. I then got a replacement M8 engine which I did a lot of work on (raised compression, ported, lightened flywheel, etc) and it was even quicker.
Unfortunately, because the M8 engine was quite a bit heavier than the A7, it tended to go straight on at corners but was good fun in a straight line. It had a 'Bowdenex' brake conversions which was coded language for 'practically useless'.
![](http://images2.snapfish.com/232323232%7Ffp83232%3Euqcshlukaxroqdfv638%3B%3Dot%3E2698%3D79%3B%3D329%3DXROQDF%3E28%3B794334%3B238ot1lsi)
![](http://images2.snapfish.com/232323232%7Ffp83232%3Euqcshlukaxroqdfv%3B34%3A%3Dot%3E2698%3D79%3B%3D329%3DXROQDF%3E28%3B7947347238ot1lsi)
Edited by - kimber on 02/12/2013 07:42:15 |
1472 Posts |
Posted - 02/12/2013 : 10:53:37
Don't blame the Bowndenex! MGs also have Bowden brakes, and just about every vehicle has Bowden handbrake cables. (Invented by an Irishman, Ernest Monnington Bowden, in 1896. In 1900 he licenced Raleigh to produce them which sometimes causes confusion since (Sir)Frank Bowden was the brains behind Raleigh and is sometimes credited with the invention.
MaGic_GV
868 Posts |
Posted - 02/12/2013 : 11:37:54
I have somewhere a booklet published by Cambridge Engineering with details of their specialities(!) Building a special was always an ambition of mine, but never happened due to a combination of finance, facilities, elbow grease (lack of), other interests (I could go on...) it never happened.
Regards, Graham
744 Posts |
Posted - 02/12/2013 : 14:24:37
iCarCheck says the registration belongs to a 1938 Austin.
1529 Posts |
Posted - 02/12/2013 : 18:26:36
I do! Agree nothing wrong with Bowden cables in principle, however, the cable routing in the case of the A7 was unhelpfully tortuous. |
1240 Posts |
Posted - 02/12/2013 : 19:02:00
Andrew
The bowden cables I fitted to the front brakes of my A7 special followed a pretty smooth path, from the centre of the cross shaft to the backplate. They were certainly a big improvement on the original open cables, which became ineffective when the front axle moved slightly backwards under braking, as there was no compensation between the front and rear cables.
I based the body of my special on the Lotus 6, with an ali covered ash frame. As an impecunious enthusiast the maxim was if it weighs anything it is too heavy and if it costs anything it is too dear. The bible was the 750 Motor Club 'Special Builders Guide' which i still have. This rather fuzzy picture shows it before the nose cone was fitted.
![](http://www.triple-mregister.org/forums/uploads/Peter Scott/201312219_a7 special2003X08X24_0001DSCN1578.JPG) |
Edited by - Peter Scott on 02/12/2013 19:21:58 |
1529 Posts |
Posted - 02/12/2013 : 20:18:31
Great stuff!
I see you've got the 'allowed' single headlamp as per the Don Moore MG.
I'm surprised Orstin hasn't commented yet, being previously of the Longbridge pursuasion ;-) |
Edited by - kimber on 02/12/2013 20:20:05 |
Posted - 02/12/2013 : 21:00:13
Peter, might one enquire who is the young person depicted?
Dick Morbey PA/PB 0743 Nr. Henley-on-Thames, Oxon, UK |
