Posted - 23/02/2016 : 10:11:34
Thank you Alan. In the general scheme of life it is not the first time that I have been overlooked, but being instantly forgettable is just something that I will have to live with !
I look forward to seeing you in April.
best wishes,
Colin. |
Adrian Moore
92 Posts |
Posted - 28/02/2016 : 10:34:16
Dad at castle Combe in the 60s
Insert Image: ![](http://www.triple-mregister.org/forums/uploads/Adrian Moore/201622718_image.jpeg)
Adrian Moore |
Kim
8 Posts |
Posted - 01/03/2016 : 21:27:33
Many thanks for all the info and photos. Quick update, PB now running, although top end more than a little clattery!. I think Paul was about to undertake a full engine rebuild, as the PA block in the car has patches bolted too it, and seems to be 'oozing' coolant from numerous places!. The charging system doesn't (surprise, surprise). But on the plus side the clutch works. Hopefully it will run long enough to do the Kimber. I have bought numerous spares with the car including two original double breather blocks (eng numbers 1417AP and 2210A over 165P, if anybody recognises them?) . Both need work, but hopefully saveable. Kim |
911 Posts |
Posted - 01/03/2016 : 21:59:20
B-o-A to West Cocker, do the Kimber & back again on 1 battery charge...... no problem. You're only 3 miles further up the road & I even carry a spare!
JH |
Posted - 02/03/2016 : 10:01:43
Hello Kim,
1417AP was originally in PA1160 (which lives in Newent Gloucestershire)
2210AP was originally with PA1992 (there is no record of that car having survived)
Posted - 02/03/2016 : 10:02:35
Kim, With all that fluid oozing out, make sure you bring a "spill-kit". The environmental police will not let you start without one !
Look forward to seeing you and Steve at West Coker in April.
Kim
8 Posts |
Posted - 07/03/2016 : 20:41:09
Further update!, Clattery top end found to be loose cam follower. Now driven a few miles and 'most' things are working....Just picked up some 400 Blockleys, as most tyres fitted are nearly as old as me!. Managed to get some play out of the steering, now need to get it running better, as 'fluffing' at @3000rpm, could be fuelling, as it seems to get worse with boost. More tinkering tomorrow.. Does anybody have dimensions for spacer that goes between the 2 spare wheels, or if anybody now makes/sell them?. regards Kim |
John Reid
704 Posts |
Posted - 07/03/2016 : 22:28:40
Kim,
I have one of the twin spare wheel spacers for which I can do you a drawing, if that helps.
John R |
941 Posts |
Posted - 08/03/2016 : 07:32:42
John
The J3 3772 which was once in your ownership, is shown in an early photo as having twin spares, the original owner appears to have bought every bell and whistle available. The necessary attachment for this is long since lost (unless you have them!), but it would be nice to have the option again.
Could you supply me with the drawing too, please.
Ian Bowers OD 6791 J3 3772 |
John Reid
704 Posts |
Posted - 08/03/2016 : 09:36:25
Ian,
That's over 50 years ago! When I had the J3 it was much more J2 spec and a shadow of its former self - at the time I didn't know about its trials history or the original spec sheet. Sadly no evidence of twin spares came with the car.
I will look out my parts and make a drawing or probably ask Alexander to model it on his CAD system. My version of the spacer between the wheels is a machined casting, and is a replacment item. It can be made fairly easily by machining from aluminium bar. It could be that there is an original item on one of the Cream Crackers.
John R |
481 Posts |
Posted - 08/03/2016 : 17:56:14
Is it the same as the drawing on page 50 of Roger Thomas's "MG Trials Cars", which says it is for a later Crackers - TA's!
Mike Dalby |
John Reid
704 Posts |
Posted - 08/03/2016 : 23:58:12
Thanks for the reminder, Mike. I had forgotten about that drawing. I wonder if there are any dimensioned drawings of components in existence to complement this GA drawing.
The spacer shown is very similar to the one I have. I don't recall the TripleM trials cars having the additional support brackets (good idea though) but rear view photos are hard to find for evidence.
John R |
John Reid
704 Posts |
Posted - 09/03/2016 : 16:04:30
Here's a photo of the spacer I have. Supplied by Octagon Sports Cars many years ago. John R
![](http://www.triple-mregister.org/forums/uploads/John Reid/20163916_image.jpeg) |
Kim
8 Posts |
Posted - 14/03/2016 : 20:34:14
John, Many thanks for photo, if you have some dimensions it would be very helpful, and I'll get a batch made. I spent a happy couple of hours going through boxes of bits with Adrian at the weekend, but didn't find a spacer!. One very battered aluminium bonnet in amongst the bits, that Paul had used on the PB is I think the original Aluminium bonnet that was made for the PB Cream Cracker JB7521,as it has the chassis number on the hinge !, it also has the bonnet catches with it, that are also cast in aluminium, I think the works were taking lightening pretty seriously. I do vaguely remember Dad having an aluminium bonnet that he let Paul have with the car in 1972!. Do any of the other Cream Cracker owners have original aluminium bonnets that might be able to confirm this?. I'll get a photo shortly. |
ags
275 Posts |
Posted - 15/03/2016 : 00:20:17
Hi Kim,
Could you please note me as "interested" in having one of the twin spare wheel spacers if you do have a batch made.
Somewhere along the way I did pick up one of the tubular parts that secures the wheels to the standard P type carrier, but have not yet got the spacer part. I could certainly bring along some photographs to the Kimber and some dimensions. It strikes me that this may be just as difficult a part to remake as the spacer.
I will certainly make contact with you and your Dad during the event in April, provided that my silencer does not become detached quite so frequently as in the last couple of events so that I am left with some chatting time.
In passing, I still think of your Dad as the Grand Master of the P gearbox having witnessed him going from First or Second to Reverse, silently, whilst still travelling forwards on the hard surfaced car park in Cheddar during one the those late lamented events in the mid seventies. Since he completed the tests, and probably won the Gymkhana event, he had kept the crown wheel, pinion, differential and half shafts intact as well. That was in the green PB which you have just regained, too!
Just plain ramblings,
Andrew Smith MMM571 - PB - Abergavenny |
